What Do I Go For ?
Little Dal
Heya all
i have Magura HS33's on my bike at the mo cleaned it all up took all the tar everything off but it dosent even work now ( cleaned with white Spirit ) what the best way to do it so it will lock up straight away with no problem
or would it be better if i go to disk what do you think please give me a tip to get it working better
Thank You :D
Dal
  • 3 weeks later...
if you have an angle grinder then you could grind the rim your self or get the local bike shop to grind it.
also i know what pads you are on about because i have them on the rear at the moment and there not to bad but if you want to have a grind on your front i suggest getting some hard brake pads or if you want to keep a smooth rim get some soft pads also you could rough the pads up with a bit on sand paper as that can help :)
er sorry not sure what pads they are they are half black and half red :)
They'll be magura koolstops and should never be used for trials. New pads will makes the world of difference!
