onzatrip Posted February 18, 2011 Report Share Posted February 18, 2011 Hi peeps i need to service my hub and axle feels abit rough... so what im wanting to know is how to remove and refit the axle?? im sure i saw a video somewhere to do this??? Thanks Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted February 19, 2011 Report Share Posted February 19, 2011 rubber hammer... Quote Link to comment Share on other sites More sharing options...
Stan Shaw Posted February 19, 2011 Report Share Posted February 19, 2011 Remove the wheel from the bike and give the axle a tap with a mallet, it'll push the opposite bearing out. The axle will then pull out. If the axle is feeling rough its probably because the bearings need replacing. There isn't much to service as such, because there is only an axle and two bearing in the hub shell. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted February 19, 2011 Author Report Share Posted February 19, 2011 Remove the wheel from the bike and give the axle a tap with a mallet, it'll push the opposite bearing out. The axle will then pull out. If the axle is feeling rough its probably because the bearings need replacing. There isn't much to service as such, because there is only an axle and two bearing in the hub shell. So just bash it out?? Yeah im thinking its bearings just wana check! Cheers buddy Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted February 19, 2011 Report Share Posted February 19, 2011 yup,simple as that Quote Link to comment Share on other sites More sharing options...
