A Little Help With Brakes ?
BradJohnson
Hi i was just wondering what i should do,
i have v brakes on my bike and truthfully they are terrible they slip as soon as im up on the rear wheel. :angry:
i need help choosing a brake that wont slip as much should i buy TNN vee pads
or should i get the 2011 hs11 with evo adaptors.
Or anyother suggestions.
i tried having a grind but i polished off after a few rides
Thanks.
Thanks.
If it was dead after a few rides it must be off been really light, try and steepen the angle when your grinding but not too much that you crack the rim obviously. With pads its just personal preference but TNN are supposed to be good.
If your frame has V mounts, I'd certainly advise against going to Magura . Besides which , a correctly set up V can easily rival the performance of even an HS33. What exactly does your brake consist of - which levers , cable and calipers ? With a regrind , a pair of the pads suggested above and some careful setting up , you'll soon have every confidence when on the back wheel .
