CriminalTrials.co.uk Posted February 18, 2011 Report Share Posted February 18, 2011 Hi all Basically i have an old Koxx LB frame and have used a standard 22t Middleburn bash and crank setup for years, however after moving to a Heatsink bash with 18t chainring, after tightning the crank bolt pushing the crankset onto the bb fully, it rubs on the outer ring of the Bottom Bracket. See Below: Im not sure what BB i have but it is like my frame pretty old. Here is a close up of the BB axel and the crankset itself: Im guessing its the BB at fault but what width would i need for this setup to work? Thanks in advance guys! Danny Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted February 18, 2011 Report Share Posted February 18, 2011 A longer BB will sort it out for you (the shell width will be the same, which is the bit that fits the frame and is most often 68mm) A 128mm axle will cover almost every setup Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted February 18, 2011 Report Share Posted February 18, 2011 Longer BB needed, that one looks like a 113 or 118, you'll need 122.5 or 127.5 Quote Link to comment Share on other sites More sharing options...
Muel Posted February 18, 2011 Report Share Posted February 18, 2011 Just get a 128mm bb, sorted. Although I preferred to run the shortest BB possible when I rode, because my feet were closer together. Dunno why, just felt more comfortable. Quote Link to comment Share on other sites More sharing options...
CriminalTrials.co.uk Posted February 18, 2011 Author Report Share Posted February 18, 2011 A longer BB will sort it out for you (the shell width will be the same, which is the bit that fits the frame and is most often 68mm) A 128mm axle will cover almost every setup Longer BB needed, that one looks like a 113 or 118, you'll need 122.5 or 127.5 Just get a 128mm bb, sorted. Although I preferred to run the shortest BB possible when I rode, because my feet were closer together. Dunno why, just felt more comfortable. Thanks, thanks and thanks Adam you will be recieving an order come pay day hehe. Cheers guys. Danny Quote Link to comment Share on other sites More sharing options...
