bagre15 Posted February 16, 2011 Report Share Posted February 16, 2011 Hey guys, I have a litle question. Is it ok to do a water bleed in an Echo TR brake? Is it the same bleeding technique of magura's bleeding? Can somebody post a tutorial of water bleeding? Thanks Quote Link to comment Share on other sites More sharing options...
Revolver Posted February 16, 2011 Report Share Posted February 16, 2011 Tutorial is in a link in my sig. You can water bleed an echo brake. Water is thinner than oil, so if your echo brake leaks with oil, it will definitely leak with water. If if doesn't leak oil, it probabnly won't leak with water Quote Link to comment Share on other sites More sharing options...
