Custom Aluminium Frames
Rob Leech
Hi all,
I've been pondering this for a while really and was just wondering what you lot think would be a reasonable price for a custom made aluminium frame?
Considering the extra work that has to go into aluminium (mainly heat treatment) and the obvious weight advantages over steel, i was thinking that 300 for a basic setup (ie- pretty standard machining work, simple tube sets, etc,etc) would be a good price for a frame that has had the desired input from yourself.
There could also the option of more technical structural work (bb yoke, custom head tube, carbon fibre additions, in-built booster, tensioning systems), but would people actually want to pay more for this?
I understand that this is very much a personal subject and that some people will have very different views on very small things, but any opinion is a help in this matter :).
Cheers,
Josh.
and this is just a ponder btw, nothing serious like (Y).
  • Like 1
I would say around the 300 mark would be more than reasonable, the only problem i can forsee is peoples trust in the brand, you would need to get a few frames out to riders for testing to build the companies reputation, and to cement peoples confidence your work
Completely agree..... my frame is on it's way out.... you know... just saying :shifty:
You need to think of a few factors.
How much you're materials are worth, and what you think you're labor is worth, as in how long you take to produce each frame.
It also really depends on the quality of the finished product. If you were to spend weeks making it, and it turns out flawed, then you couldn't really make money on it.
Hope that made sense.
Get some REALLY GOOD riders to ride your frames (if possible) and then when people see that the frame is holding out for them, that would then get you some decent rep.
Also I think that price is fair, and I would presume paying extra for add-ons such as in-built booster would be fair too.
Would the price be cheaper for 20" as well as less material is used and more likely less work (i presume?).
Just a few general questions about your frames:
How much did it weigh after?
How has it held out, did it dent easy (if dented), cracks, snap, creases?
I would be interested in getting one custom made from you, however only had my limey 320 for about 4-5 months so wont be any time soon :P
Sounds good though, will be interesting to see how this works out for you. - Topic Watched.
Take into account the following:
Material cost - try and split the cost to a one unit price.
Labor cost - should be one set price for 20" and a little more for 26" as more work is needed.
Then add a little extra on for some profit. - MARK UP PRICING.
Shipping wouldn't be included as you would add that on afterwards.
Edited by dannytrialskid
If you were able to churn out a decent quality product from £300 then you'd be doing great
When you think how Clive Leeson was churning frames out at £400+ years back, that's more than reasonable (Y)
People were cool with that because they could just re-weld and re-weld and re-weld Leeson frames (as most people had to). It's not quite the same with aluminium.
Agree completely with what your saying.
If it where to start up, i already have a few people at varying levels that have said they would test the frames for me (which is greatly appreciated) and luckily enough the trials community, in my eyes anyway, seems to be one of the freindliest and most social around, so i think that simply testing through riders would assure people of the products finish quality.
I have taken these factors into consideration with my pricing above, but only for the much simpler frames.
This is a good point, which is why i'd probably make a good few frames to go through testing before offering any sort of service.
The main thing i would like to know peoples veiws on is, in a sort of way, originality, which is one of the main things i would try and aim for in frame building.
I've got a couple of ideas that would take alot more work at production level, but would also show benefits for the riders in general.
I also think that something as simple as your own design incorperated into one of the parts of a frame would have a personal benefit, everyone loves saying this is mine and its the only one :P.
Cheers for the comments guys :).
Josh.
Indeed, but now the attitude has largely shifted to lightweight kit, with a lot of people seeing it as almost 'disposable' to an extent
BITD frames weren't all tending towards £700+, so the likes of Leeson and Curtis were priced high but it was a one off, custom product so people would plump up for it. To churn out a custom alu frame starting at £300 ten years down the line is a pretty sweet gig, provided they're not heaps of crap.
Yeah, I see what you're saying, but to an extent I think the whole trials market has changed pretty drastically in that time. I think people understood what they were paying for with a Leeson, but it's not really the same now. When you've got pretty good frames like the Blade, Comp, etc. out for £200 and under it's just sort of shifted things in many ways. I don't think a lot of riders now are as discerning as people were back then in terms of wanting custom stuff.
It would be, yes, but not by a massive amount.
The finished weight was 1.43kg.
I havent had the chance to build it up yet as im still waiting to send it off to heat treatment (which will of happened by the end of the month as i found a crack in my control the other day (N)), but when its up and running, i'll give it a good hard riding, just for you ;) and then report back.
I think there is a NEED for this in the trials market.
Very much agreed good sir.
a couple of areas that would definitely need to be nailed would be
tyre clearance for tyres such as the contis,
Gear ratio-brake mounts- Cs length calculations so that on a used chain everything matches up
these tend to be a things some brands can't seem to get
and in my opinion simplicity, some of the nicest frames out there such as the 09 control, the 2011 echo range and the fans all have really simple designs, and seem to look awesome and have no major disadvantage above the over engineered cnc monsters that some companies produce
Edited by rab shropshire
Thanks Josh, that's is a very good weight too!
Any chance of me testing the 20" :P ?
Very much agreed, just the fact that echo decided to pop the brake mounts in the wrong place on the control annoyed me, so it's something that i would take alot of time perfecting, in a word.
Josh.
For people that want something a bit more funky and/or something in particular and know what they want this sort of thing is cool. For everything else there's Mastercard.
The way I see it, if you're in a position to be looking at a custom frame then you should know what you want/need and should therefore know what you're doing. Shame it doesn't always seem to work out that way :rolleyes:
300 seems awesome for that sort of control over your own design. Would you be doing some sort of breakage warranty with them or even a repair service? I'd rather the guy who made the frame re weld it and treat it if it did have a fail.
Edited by jambo
Nail on the head there.
Problem with that is if people are choosing something that isn't suited to their needs problems will arise.
I'd happily pay up to £700 for a custom aluminium frame provided i got what i wanted with superior customer service and aftercare. Bearing in mind this would be from a reputable brand. Obviously wouldn't hand over hundreds to someone like Marino. But i don't actually want one anyway :P
I agree, I like my because simple as it is a very simple frame and I find the geo great. However theres a few niggles like tyre clearance so if when it dies I could get a replacement made with the same geo but better tyre clearance and a tensioning system like the new echos i'd gladly pay £300+ (the because is only £226).
