Echo Control Top Spec Weighs 9.1Kg
terry_harris
Hi all as i thought my frame was cracked i sanded the part i thought was cracked and its NOT thank god its just a paint defect. so got some new bits for the beast what you think
pics dont give it justice
pics
Spec
Frame-Echo control
Forks-Echo SL
Bars-Try all carbons no war
Stem-Tarty bikes forged stem
Headset-Echo SL
Bottom bracket-echo isis
Cranks-Echo sl
Pedals-Echo tr
Bash ring-Trialtech titanium halfring
Freewheel-Echo sl
Chain-Kmc cool chain
Hub-Rear-Rockman screw on 135mm fixed
Hub-Front-Echo TR disc
Rear sprocket-Trialtech screw on 15T
Front rim-Trialtech square hole-(Custom drilled sidewalls)
Rear rim-Tryall hOle
Spokes-Sapim double butted spokes-12mm steel nipples
Tyres-Tryall sticky 2.0 front--Try all sticky 2.5 rear
Rear brake-Magura HS33 with Trialtech carbon 2 bolt booster,echo SL brake clamps and tnn lgm pads
Front brake-Magura louise with carbon lever blade with IS post mount
Grips-Trialtech foams
Edited by terry_harris
