What Are Snail Cams?
Blake
Sorry to thread jack, but...
How do you know if the hub is ok for snail cams? I have a small hole in my frame which I assume is where the bolt goes, does this mean its probably ok to have them?
Yeah I have put snail cams on my DaBomb. I had to get a tap and cut a thread on the little hole though because it doesn't have one which seems a bit wierd??!!
Any way, I had to put my snail cams on the outside of the frame because they wouldn't fit on the inside. I can get a pic if you want?
Yeh that'd be awesome (Y)
http://www.flickr.com/photos/58117374@N03/5441980098/in/photostream/
Here you go...
Probably could sort it out better just haven't got around to it. Hoping to get a new back wheel reasonably soon
Thanks for that :) to be honest im not fussed what it looks like (This is obvious by the colour 'scheme' on my bike) just as long as it keeps the chain tight and wheel in-line (Y) ...Now to find to some snail cams
Haha yeah. What are you planning on changing on your Dabomb??
while on the topic of snail cams im looking to change my frame soon, looking at a because simple street which takes snail cams, can i run my hope pro 2 hub on that too or will i need to use tugs instead?
Looking at the frame i can't see why not, you'd have to run them on the outside of the dropouts though, but there aren't any real issues with this.
With that frame, the snail cam holes are drilled so far from the dropouts they're pretty much in a different post code so you may struggle to use some of the cams on the market. Just check out which give the most movement and you should be fine.
Ones with teeth click into place and stay put more than smooth ones, I'd recommend Echo TR cams as they have micronotches so they have a better range of adjustment but stay it place too :)
The 2011 cams are smooth instead of notched.
May have to put one on the outside and one on the inside as the Pro 2's 135mm as is the frame.
