BradJohnson Posted February 10, 2011 Report Share Posted February 10, 2011 will a magura rim brake fit v brake mounts if not is there any sort of converter that will convert my v mounts into a magura mount Quote Link to comment Share on other sites More sharing options...
trials owns Posted February 10, 2011 Report Share Posted February 10, 2011 http://www.tartybikes.co.uk/brake_clamps/magura_evo2_brake_adaptor_kit/c74p10934.html Quote Link to comment Share on other sites More sharing options...
Azarathal Posted February 10, 2011 Report Share Posted February 10, 2011 There are adaptors but they're pointless. Vee's can be as good as Maggys if set up properly and many people prefer them because vee's have more hold. *awaiting Ali C's wall of text* Quote Link to comment Share on other sites More sharing options...
Ali C Posted February 10, 2011 Report Share Posted February 10, 2011 I agree 3 Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted February 10, 2011 Author Report Share Posted February 10, 2011 There are adaptors but they're pointless. Vee's can be as good as Maggys if set up properly and many people prefer them because vee's have more hold. *awaiting Ali C's wall of text* i have v brakes but i cant seem to set tem up right i have bought new pads and cables and even got a rim grind but after a few hours of riding the rim was smooth again. if you have ant idea what i can do please share Quote Link to comment Share on other sites More sharing options...
Ali C Posted February 10, 2011 Report Share Posted February 10, 2011 don't drag the brakes? Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted February 10, 2011 Report Share Posted February 10, 2011 Learn to set up vees, experience win. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted February 10, 2011 Author Report Share Posted February 10, 2011 don't drag the brakes? what do you meen by 'drag the brakes' i have about 2mm gap each side of the rim between the pads and the rim Quote Link to comment Share on other sites More sharing options...
Ali C Posted February 10, 2011 Report Share Posted February 10, 2011 I mean if you are going down a hill or wanting to slow down, don't drag the brakes to slow down. If you have a disc use that or if you have ground rims front and rear (fail) then use your feet on the floor or tyre Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted February 10, 2011 Author Report Share Posted February 10, 2011 I mean if you are going down a hill or wanting to slow down, don't drag the brakes to slow down. If you have a disc use that or if you have ground rims front and rear (fail) then use your feet on the floor or tyre i only have a rear grind as i have a front cable disk, i dont do downhill riding i do trials sections and things with pallets and cable drums etc. Quote Link to comment Share on other sites More sharing options...
Ali C Posted February 10, 2011 Report Share Posted February 10, 2011 i only have a rear grind as i have a front cable disk, i dont do downhill riding i do trials sections and things with pallets and cable drums etc. with you being on a trials forum owning a trials bike and asking questions about trials related things I didn't think you were a downhiller. If you are like me and you go to ride somewhere, hills are often something that needs to be navigated. Some people tend to drag brakes when going down them, if you do this it will make your rim smooth, hence, don't do it. What pads are they out of interest? I have a rather huge hatred of Maguras, about as useful as an arse on your elbow they are. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted February 10, 2011 Report Share Posted February 10, 2011 Think me mentioned somewhere he had Clarks vee pads :l Quote Link to comment Share on other sites More sharing options...
isitafox Posted February 10, 2011 Report Share Posted February 10, 2011 TNN LGV, problem solved. Quote Link to comment Share on other sites More sharing options...
bikeperson45 Posted February 10, 2011 Report Share Posted February 10, 2011 I have a rather huge hatred of Maguras, about as useful as an arse on your elbow they are. That's a bit of a contradiction since having an arse on your elbow would be very useful. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted February 10, 2011 Report Share Posted February 10, 2011 That's a bit of a contradiction since having an arse on your elbow would be very useful. Need a crap in public. 'Lean casually on a wall with your elbow hanging over' Problem solved. 2 Quote Link to comment Share on other sites More sharing options...
Ali C Posted February 10, 2011 Report Share Posted February 10, 2011 I like to wear t shirts though Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted February 11, 2011 Report Share Posted February 11, 2011 (edited) TNN LGV, problem solved. Or inspired phats. Mine are epic on the front with a touch of tar so should be more than enough for this guy on the rear. (and he wouldn't have to re-grind) Could it also be the rim at fault here? The rims on starter bikes (his sig says he has a phase 1.3) don't hold a grind for long because they are soft and not designed to be ground.(thats my experience anyways) Edited February 11, 2011 by CC12345678910 1 Quote Link to comment Share on other sites More sharing options...
TrialsMan Dan Posted February 11, 2011 Report Share Posted February 11, 2011 Could it also be the rim at fault here? The rims on starter bikes (his sig says he has a phase 1.3) don't hold a grind for long because they are soft and not designed to be ground.(thats my experience anyways) probably true i had unbranded wheels for a while before i got my Atomlabs and they seem to come up better when ground. Yes it is true you can run a maggie on vee mounts with the Evo 2 adaptors but they are very difficult to set up properly and the pads always wear down at an angle somewhere or one pad wears down faster than the other (is there a secret to get it right?) and from recent experience the clamps come loose and move slightly under heavy braking, unless i am tightening the bolts too tight? Someone want to guide me to the correct method of set up cause im inreasingly moving towards changing for a disc on the rear. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted February 11, 2011 Report Share Posted February 11, 2011 I ran the evo adaptors on my old et24 and didn't have the slightest issue in the 18 months or so that I was running them Quote Link to comment Share on other sites More sharing options...
Julius Czar Posted February 11, 2011 Report Share Posted February 11, 2011 It depends what frame you have, if you have a 19" back wheel, the evo adaptor bends out where the frame is wider to accommodate for it, thus making one of the calipers wonky, as magura's aren't trials specific, they're made for mountain bikes with slimmer wheels/mount spacing. Quote Link to comment Share on other sites More sharing options...
TrialsMan Dan Posted February 12, 2011 Report Share Posted February 12, 2011 I ran the evo adaptors on my old et24 and didn't have the slightest issue in the 18 months or so that I was running them Must be something wrong with mine then im forever having problems and the Effect frame is basically the same as the old ET around the seatstay/chainstay area. Ive found that my non drive side pad is wearing down faster than the drive side and at an angle whereas the drive side is perfect. Also when i go to set my brake up the lower mounting plate always seems to move and the clamps move a bit too, might be due to my pads not equal? Im getting my wheels back from my LBS soon anyway as they are in for a quick tune and i'll get some fesh pads to see if it makes any difference. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted February 12, 2011 Author Report Share Posted February 12, 2011 It depends what frame you have, if you have a 19" back wheel, the evo adaptor bends out where the frame is wider to accommodate for it, thus making one of the calipers wonky, as magura's aren't trials specific, they're made for mountain bikes with slimmer wheels/mount spacing. i ride a stock 26" Quote Link to comment Share on other sites More sharing options...
Julius Czar Posted February 12, 2011 Report Share Posted February 12, 2011 i ride a stock 26" Still applies to that, you dont get 46-47mm wide rims on mountain bikes do you.... Evo 2's are made for mountain bikes with thinner mount spacing and thinner wheels, so your obviously gonna have problems with an evo 2 on a bike with extra wide mounts... Quote Link to comment Share on other sites More sharing options...
