Onza Zoot Pro... Build Finished Updated
Gaz96
Looks really tidy man, nice work! Definitely agree that you need to throw those spacers below the stem though - looks fairly long and low, boosting it up a little bit will make the bike pop a lot nicer and should just suit things a whole lot better. Horses for courses though, so play around a bit and find what works for you (Y)
  • 2 months later...
  • 4 months later...
Hi, may I know how are the cnc sidewalls of inspired pro rim for the rear holding up? Does it wear off like a grind?
How is the texture of the sidewall like, is it cnc'ed with fine machining grooves? (like those really fine lines we see on cnc'ed products like hope stem, etc)
And is it similar/comparable to a fairly light grind? Or does it feel like a smooth rim?
The CNC has got the fine machined groves yeah, its better than a smooth rim but couldnt comment on grind as its only my second ever bike first had smooth rims then this but I dont imagine it'll be as good as a grind but still better than smooth
Also thanks for the comments, it has been left the now with the purple, only different thing is new pedals and pads
Edited by Gaz96
  • 1 year later...
