Balls Deep trials team Posted February 3, 2011 Report Share Posted February 3, 2011 Hello people i am in need of some help. I have a magura hs33 lever (2004 style) that i was getting ready to bleed and as i pulled the lever in the piston in the lever stuck and i cant get it out ... can anyone help me to get it to work again ? cheers Quote Link to comment Share on other sites More sharing options...
Franksx2005 Posted February 3, 2011 Report Share Posted February 3, 2011 Hello people i am in need of some help. I have a magura hs33 lever (2004 style) that i was getting ready to bleed and as i pulled the lever in the piston in the lever stuck and i cant get it out ... can anyone help me to get it to work again ? cheers Take the hose off the lever and push something thin in the hole to push the piston back out again. spring maybe shagged Quote Link to comment Share on other sites More sharing options...
Balls Deep trials team Posted February 3, 2011 Author Report Share Posted February 3, 2011 Take the hose off the lever and push something thin in the hole to push the piston back out again. spring maybe shagged cheers ill give that a go now . Quote Link to comment Share on other sites More sharing options...
pogo Posted February 5, 2011 Report Share Posted February 5, 2011 Same thing happened to me but i replaced the spring only a few months ago, is there any other things that could cause it? Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted February 5, 2011 Report Share Posted February 5, 2011 (edited) Same happened to me, took it to my LBS who said it was dead. New lever. Edited February 5, 2011 by Luke Dunstan Quote Link to comment Share on other sites More sharing options...
JT! Posted February 5, 2011 Report Share Posted February 5, 2011 Same happened to me, got advice to take the piston out and sand it down a little but just got a new leaver and threw the old one at a spider. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted February 5, 2011 Report Share Posted February 5, 2011 Had this happen to me a ton of times now. You need to shove a really small allen key down the hole. I left the piston soaking in cycle oil or whatever stuff it was, £1 oil from the £1 shop. And plugged it in the next day and it returns super smooth. I would have sanded around the oring too but I don't have sandpaper in my room. Quote Link to comment Share on other sites More sharing options...
JT! Posted February 5, 2011 Report Share Posted February 5, 2011 (edited) Dubble post. Edited February 11, 2011 by JT! Quote Link to comment Share on other sites More sharing options...
