Echo Tr
onzajorge
My bro has the TR wheel on his blade with the same drop outs and yeh with out the snail cams it does fit.
One problem we faced though is that because the TR hub body is quite wide you might find that the chain or sprocket will hit the drop outs. We solved this by using the Echo TR sprocket which has the teeth in the middle and the sprocket and it now clears nicley with a 18:12 gear ratio.
Ok thanks mate ... does sprocket come with the wheel or have to buy the TR sprocket seperate?
Is it a pain to sort or just 20mins work? lol
The sprocket's sold seperately. Depending on the sprocket you've got, you may be able to flip it over and use a thin spacer to keep it spaced away from the spoke heads so it'll end up in a TR-ish position.
Right ok thanks.
Just wondering before I try.
Thanks for your help mate.
I wouldn't do that from pure experience this could cost you a whole new hub.
Did exactly what you suggested there Mark with a Alu (some sort of spare HollotechII spacer around 2.5mm) and sprocket managed to strip the threads on the hub in less than a days ride, I'm not a particularly heavy rider and I really wouldn't recommend doing it at all.
Save yourself a new hub and wheelbuild by doing it properly.
Steve
Viz hub and Viz Sprocket, and I've seen the threads on a TR strip infront of me with all the threads used by the sprocket, I'm steering away from screw ons if I can now!
Steve
I've only heard of this with certain hubs and freewheels, i think it was Eno's but never with a sprocket?
Steve
Ok cheers ... but how do i do it properly then so this doesn't happen?
I need to fir before sunday and am struggling?
Is there a better way to fir the TR on The Pro?
never say never! it happens mate.
doing it properly requires you to get a sprocket that has the tooth aligned in the middle I mean, just try and not bodge anything...
Steve
