Pedaling Backwards
onza1
Yeh they are letting the drivetrain pedal there legs backwards and controling the speed, but you don't pedal backward frantically backwards just go with the flow, also do a small endo and let go of the brake by using you momentum to roll backwards.
Oh yeh and lean back quite far to keep your balance and gives more room to move you legs around.
