supertrialer Posted January 23, 2011 Report Share Posted January 23, 2011 Hi guys. Well, I was building my new front wheel when I realised that the hub has a 'little' problem..if you look at the pics you can see that the hub holes, where you insert the spokes are in te same 'line. The hole where the spoke is shouldn´t have a hole right in front of the ohter side of the hub. (sorry about my english) Is this a problem on the hub or its normal in this viz hubs?? Normal Hub Hub Problem Sorry about the cellphone quality. Thanks, David Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted January 23, 2011 Report Share Posted January 23, 2011 Should be fine I think Quote Link to comment Share on other sites More sharing options...
supertrialer Posted January 23, 2011 Author Report Share Posted January 23, 2011 Do you think theres no problem with the hub?! Weard, I've never seen one like this one..thabks anyway.. Any different thoughts about it? Quote Link to comment Share on other sites More sharing options...
supertrialer Posted January 24, 2011 Author Report Share Posted January 24, 2011 Does anyone have a diferent opinion or you just think its fine? pelase help me :/ Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted January 24, 2011 Report Share Posted January 24, 2011 I fail to understand what you are saying at all. Quote Link to comment Share on other sites More sharing options...
cai Posted January 24, 2011 Report Share Posted January 24, 2011 I fail to understand what you are saying at all. Really? He's saying that the spoke holes in the flange on each side of the hub line up with each other, when they are usually offset. The photo below shows how spoke holes should be laid out. So if you put a spoke straight through a spoke hole on one flange, it should end up in the middle of two spoke holes on the other side: Where as he is saying his spoke holes are not offset, so the holes on each flange line up. I can't see it being a problem though if you have the correct length spokes, as the non-disc side of Viz hubs are usually laced radially (0 cross spoke pattern) Quote Link to comment Share on other sites More sharing options...
supertrialer Posted January 24, 2011 Author Report Share Posted January 24, 2011 Really? He's saying that the spoke holes in the flange on each side of the hub line up with each other, when they are usually offset. The photo below shows how spoke holes should be laid out. So if you put a spoke straight through a spoke hole on one flange, it should end up in the middle of two spoke holes on the other side: Where as he is saying his spoke holes are not offset, so the holes on each flange line up. I can't see it being a problem though if you have the correct length spokes, as the non-disc side of Viz hubs are usually laced radially (0 cross spoke pattern) Exactly, that's my problem..but with my hub the spokes are going to be a little bit 'unradial', I mean bent, in the radial side.. Sorry about my english, but I don't know some expressions..and thanks Quote Link to comment Share on other sites More sharing options...
cai Posted January 24, 2011 Report Share Posted January 24, 2011 Hopefully you can see what I mean by 'radial' in this photo. On the side of the hub with no disc mount the spokes just go directly from the hub to the rim, without overlapping other spokes - this is called 'radial', or '0 cross'. But on the side of the hub that has a disc mount the spokes overlap (or cross) other spokes. This particular pattern is called '3 cross' because if you follow one spoke from the hub to the rim it would have crossed 3 other spokes. Understand now? If not I can try and explain again Quote Link to comment Share on other sites More sharing options...
supertrialer Posted January 24, 2011 Author Report Share Posted January 24, 2011 I haven´t explained well. I know what radial is, but because theres no offset in the falanges the radial side will be a bit bent I think..sorry if i cant explain myself in the better way Quote Link to comment Share on other sites More sharing options...
cai Posted January 24, 2011 Report Share Posted January 24, 2011 Oh I understand you now. I think you should just build it all up as you should still be able to get the wheel straight and true. Quote Link to comment Share on other sites More sharing options...
supertrialer Posted January 24, 2011 Author Report Share Posted January 24, 2011 ok mate, thank you Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted January 26, 2011 Report Share Posted January 26, 2011 Hi David, Tried to reply to your email but it said your inbox was full. Thanks, Adam Quote Link to comment Share on other sites More sharing options...
supertrialer Posted January 26, 2011 Author Report Share Posted January 26, 2011 Weard..But thanks anyway Adam. My friend have already send it to me Quote Link to comment Share on other sites More sharing options...
