SamKidney Posted January 23, 2011 Report Share Posted January 23, 2011 Right guys, story goes as so. All ive ever done since starting trials was smooth rims, 2 bolt booster, tar or no tar, citrus pads or limes. Always worked great. However about 4 months ago i had a new wheel built along with a grind. I used my limes on this and worked fine. Recently i bought a set off Tnn LGMs and were great at first on a fresh medium grind, then one day i removed my rear wheel and its not been the same since ive cleaned my rim, pads, and set the brake as square as i possibly can. No avail. Cant think what it can be. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted January 23, 2011 Report Share Posted January 23, 2011 Fresh grind and sand the top of the pads square. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted January 23, 2011 Author Report Share Posted January 23, 2011 brake needed a rebleed. Will get the grind done on friday, pads are fine. Brake set up is, Zoo python 06, V!Z clamps, Echo lever, oil bleed, Trialtech Sport 19'' and Tnn Lgms. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted January 23, 2011 Report Share Posted January 23, 2011 Yup, give the pads a very light sand to get the film of dirt they could have picked up when changing set ups or whatever. Try a bath bleed, I always find these much much stronger than a bleed with a syringe. Try changing the disk you used with the initial grind, thin metal cutting disks work great at around a 45 degree from the vertical. My money is on the grind though... Quote Link to comment Share on other sites More sharing options...
