Gaz96 Posted January 22, 2011 Report Share Posted January 22, 2011 As the topic description says, when I try to unscrew the allen key bolts, only one side comes out, the otherside stays the same. I've tried turning both bolts seprately but its only ever the non disk side that comes out. Any help needed! Do i have to turn both bolts at the same time? Thanks in advance Quote Link to comment Share on other sites More sharing options...
AndrewG Posted January 22, 2011 Report Share Posted January 22, 2011 (edited) put your hup to vice and try to do that or unscrew first that bolt which is wrong Edited January 22, 2011 by AndrewG Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted January 22, 2011 Report Share Posted January 22, 2011 Put an Allen key in each one and try it? Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted January 22, 2011 Report Share Posted January 22, 2011 Tighten the one thats coming out quite tight, then try undoing the one thats not budging Mite work . Josh. Quote Link to comment Share on other sites More sharing options...
