Mtchell Posted January 22, 2011 Report Share Posted January 22, 2011 Hi As title says managed to snap a tensile crank and the freewheel is on there still i just want to know is it going to be possible to remove the freewheel with out the leverage of the crank arm ? any advice would be appreciated cheers Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted January 22, 2011 Report Share Posted January 22, 2011 Depends on the freewheel and how much is left of the crank. I'd put the crank in a vice and bolt the tool in and put a bar on the freewheel tool. Probs easier if it's a tensile as they use a BB tool. Quote Link to comment Share on other sites More sharing options...
davidbarr Posted January 22, 2011 Report Share Posted January 22, 2011 It should still be alright. You could put a long metal tube on it for leverage. http://www.tartybikes.co.uk/media/guides/maintenance_freewheel_and_sprocket_removal/m1.html Quote Link to comment Share on other sites More sharing options...
Krisboats Posted January 22, 2011 Report Share Posted January 22, 2011 If it snapped like mine did it will be pretty hard to get a decent enough grip on it due to the huge curve on one side. I whacked mine in a vice and ground away the top half of the cranks (the only remaining bit of the arm. Then the bashring fell off and i unwound it by hand. The crank was destroyed anyway and i'm unsure if onza will even half price replace tensile stuff, i know they get really pissy about zona not being covered like onza so won't do it for them. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted January 22, 2011 Author Report Share Posted January 22, 2011 No its a Tab one Viz 72 freewheel don,t know weather its worth hassle now :/ If it snapped like mine did it will be pretty hard to get a decent enough grip on it due to the huge curve on one side. I whacked mine in a vice and ground away the top half of the cranks (the only remaining bit of the arm. Then the bashring fell off and i unwound it by hand. The crank was destroyed anyway and i'm unsure if onza will even half price replace tensile stuff, i know they get really pissy about zona not being covered like onza so won't do it for them. Yer its snapped right near the top of the crank , only the curved bit left sounds like a night mare may well just buy a second hand one for time being Quote Link to comment Share on other sites More sharing options...
Krisboats Posted January 22, 2011 Report Share Posted January 22, 2011 No its a Tab one Viz 72 freewheel don,t know weather its worth hassle now :/ Yer its snapped right near the top of the crank , only the curved bit left sounds like a night mare may well just buy a second hand one for time being It's really not that bad, only takes a few minutes with a grinder. Once you've gotten the top bit off the bash will just lift off and you can unscrew your freewheel by hand. Think mine took about 5 minutes and i took a while making sure i got it all perfect with no marks on the bash. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted January 22, 2011 Author Report Share Posted January 22, 2011 It's really not that bad, only takes a few minutes with a grinder. Once you've gotten the top bit off the bash will just lift off and you can unscrew your freewheel by hand. Think mine took about 5 minutes and i took a while making sure i got it all perfect with no marks on the bash. Oh right i see what your saying now mate well ill give that try before i go buying one ill report back Quote Link to comment Share on other sites More sharing options...
onzatrip Posted January 22, 2011 Report Share Posted January 22, 2011 get a hacksaw and cut were eg the bashring would meet the cranks so the threads have nothing to tighten agianst and the freewheel will be able to screw off using your hands Quote Link to comment Share on other sites More sharing options...
Mtchell Posted January 22, 2011 Author Report Share Posted January 22, 2011 get a hacksaw and cut were eg the bashring would meet the cranks so the threads have nothing to tighten agianst and the freewheel will be able to screw off using your hands Yer i,m going to give this a try this afternoon see if it works Quote Link to comment Share on other sites More sharing options...
onzatrip Posted January 22, 2011 Report Share Posted January 22, 2011 yup it does work dont it to 3 sets of cranks now Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted January 22, 2011 Report Share Posted January 22, 2011 I tried cutting through my bashring and it took years with a hacksaw!! Quote Link to comment Share on other sites More sharing options...
onzatrip Posted January 22, 2011 Report Share Posted January 22, 2011 I tried cutting through my bashring and it took years with a hacksaw!! just the other side of the bashring so the crank falls apart Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted January 22, 2011 Report Share Posted January 22, 2011 just the other side of the bashring so the crank falls apart Do you mean the lip on the bashring? Quote Link to comment Share on other sites More sharing options...
Mtchell Posted January 22, 2011 Author Report Share Posted January 22, 2011 Do you mean the lip on the bashring? If i cant sort it luke ill take that tensile of your hands bud Quote Link to comment Share on other sites More sharing options...
Simpson Posted January 22, 2011 Report Share Posted January 22, 2011 It's really not that bad, only takes a few seconds with a grinder. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted January 22, 2011 Report Share Posted January 22, 2011 If i cant sort it luke ill take that tensile of your hands bud Yeah no probs mate Quote Link to comment Share on other sites More sharing options...
Mtchell Posted January 22, 2011 Author Report Share Posted January 22, 2011 yup it does work dont it to 3 sets of cranks now Couldn,t find the grinder nor the big hacksaw so had a go with a little shatty old school one lol a hour later with a few blisters to the thumbs it fell apart and the free wheel is sound Thanks for your advice man, legend Thanks guys !!! Quote Link to comment Share on other sites More sharing options...
