Dave Anscombe Posted January 19, 2011 Report Share Posted January 19, 2011 im off to the shop tomorrow to get me a grinding disc......... what should i go for metal cutting or grinding stone cutting or grinding its been so long i cant remember much also what thickness is ideal ? cheers for any help Quote Link to comment Share on other sites More sharing options...
dann2707 Posted January 19, 2011 Report Share Posted January 19, 2011 Metal cutting and pretty thin works perfect. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted January 19, 2011 Report Share Posted January 19, 2011 I would say metal grinding and thick! Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted January 19, 2011 Report Share Posted January 19, 2011 Adam said stone cutting and I believe him Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted January 19, 2011 Author Report Share Posted January 19, 2011 i guess many people use different thing its why i never know what to use....i cant remember what i used to use...........stone cutting hummmmmmmm i guess il go with that then Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted January 19, 2011 Report Share Posted January 19, 2011 Metal cutting thick. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted January 19, 2011 Report Share Posted January 19, 2011 I could have sworn he said it doesnt really matter what type of disk but more of the angle you hold the disk... Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted January 19, 2011 Report Share Posted January 19, 2011 just for you http://www.tartybikes.co.uk/media/guides/maintenance_rim_grinding/m2.html Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted January 19, 2011 Author Report Share Posted January 19, 2011 if its good enough for the fellas at tartybikes its good enough for me thanks for posting up that video Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted January 19, 2011 Report Share Posted January 19, 2011 You´re welcome. Quote Link to comment Share on other sites More sharing options...
Jon Alty Posted January 21, 2011 Report Share Posted January 21, 2011 Doesnt a thicker disc generally give a harsher grind? Obviously its how much pressure + the angle of the disc aswell, but i think the thickness does effect it. I think a thinner disc is usually best (lighter grind), as you can then change harshness with pressure + angle? Im sure someone will correct me if im wrong . Quote Link to comment Share on other sites More sharing options...
