Smifee Posted January 18, 2011 Report Share Posted January 18, 2011 Just brought a Magura Julie off ebay cheap... Came with a 160 rotor i believe... However when i bolted the disc on the wheel and the caliper to the forks the disc is too small... It's on a onza Spyro gyro.. Standard forks.. Anyone had this before ?? Know what disc i should Buy ?? Quick response be nice so i don't buy somethin i don't need Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted January 18, 2011 Report Share Posted January 18, 2011 (edited) It may have a +20 disc mount on it but as it is a standard fork it proberly won't, a 180mm rotor will work if it is, the Julie may have come with 180mm IS adaptor so you could get a 160mm adaptor. A bigger rotor will make your brake perform better though. Edited January 18, 2011 by Milo123 Quote Link to comment Share on other sites More sharing options...
davidbarr Posted January 18, 2011 Report Share Posted January 18, 2011 Just brought a Magura Julie off ebay cheap... Came with a 160 rotor i believe... However when i bolted the disc on the wheel and the caliper to the forks the disc is too small... It's on a onza Spyro gyro.. Standard forks.. Anyone had this before ?? Know what disc i should Buy ?? Quick response be nice so i don't buy somethin i don't need You will need to buy an adapter, Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 18, 2011 Report Share Posted January 18, 2011 You will need to buy an adapter, No, he will need to buy a larger disc rotor. Measure the gap between the rotor and the outer edge of the brake pad and multiply it by 2. That's how much larger the new disc will have to be. Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted January 18, 2011 Report Share Posted January 18, 2011 Would say a bigger disk is needed. Give tarty a phone in the morning. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted January 19, 2011 Report Share Posted January 19, 2011 I would check if the adapter isn´t fitted upsidedown first. Quote Link to comment Share on other sites More sharing options...
Matt Burrows Posted January 19, 2011 Report Share Posted January 19, 2011 I would throw the magura julie brake in the bin and buy something that actually works for trials Quote Link to comment Share on other sites More sharing options...
