bike_dummie Posted January 13, 2011 Report Share Posted January 13, 2011 hi i have a few questions so i will fire away thanks! 1. just got a new skf bb not sure but my cranks will fit properly because the bolt that holds them of is the wrong size so will that matter? also they are truvati hussefelt cranks 2.what size are the o rings used in the 04 hs33? 3.how spongy should the lever be because mine is quite spongy ? 4.what pad is best tnn LGM or rockmans blue prefer advantages and disadvantages instead of someone just saying rockman? 5.any tips on setting up hs33 with evo mounts? Thanks Adam Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted January 13, 2011 Report Share Posted January 13, 2011 5. don't use the quick release thingy just use another bolt like the normal one, also try and get your hands on a another brake booster to double it up a single one is abit flexy Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted January 13, 2011 Author Report Share Posted January 13, 2011 (edited) Thanks i was thinking of getting a 4bolt booster instead of 2bolt but if i doubled up what would be stiffest? Also i meant the adapter ones for the v-brakes to maggy. Cheers Adam Edited January 13, 2011 by bike_dummie Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted January 13, 2011 Report Share Posted January 13, 2011 The evo 2 adaptors only work with the magura boosters if you have a standard v brake mount spacing its about 80mm. Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted January 13, 2011 Author Report Share Posted January 13, 2011 ok thanks for the help Quote Link to comment Share on other sites More sharing options...
bike_dummie Posted January 14, 2011 Author Report Share Posted January 14, 2011 anyone?anyone? Quote Link to comment Share on other sites More sharing options...
