My Python '09
Zoo!Man
Hi mates! I've had this bike for over a year and a half, but yesterday I received some new rear rim and spokes, pedals and grips, and though I'd share with you (sorry about the sh*it quality, took the pics with the my phone). Hope you like it, ZOO! Python '09:
The spec is:
Frame and Forks
- Frame: Zoo! Python '09
- Forks: Echo Lite, Hs mounts removed due to cracking them
Wheels
- Front hub: Trialtech Sport, Black
- Rear hub: Trialtech Sport, Black
- Chain tensioner: Monty Snail Cam
- Front rim: Trialtech Sport, Black
- Rear rim: Zhi 48 mm, White NEW!
- Front tyre: Try All Sticky
- Rear tyre: Maxxis Creepy Crawler
Brakes
- Front brake: Hope Mono Trial, with rear caliper (so it fits a 180 mm disc)
- Rear brake: Magura HS33, Black, Long lever blade
- Brake pads: One Coust on plastic backings and one Tnn Belaeys on Alu backings (rear).
- Brake clamps: Zhi modified
Drivetrain
- Cranks: Trialtech Sport,175 ISIS
- Freewheel: Zhi 18T, 72 engagement
- Chain: Shimano don'tknowthemodel
- Rear Sprocket: Trialtech 12T Screw On
- Pedals: Wellgo Platform Magnesium, White NEW!
- Bottom bracket: Trialtech Sport Lite ISIS
- Bashring: Neon, Red (N)
Steering
- Headset: Zhi
- Stem: Trialtech Sport, Black
- Grips: Viz Rubber, Transparent
- Handlebars: Trialtech Risers
Geometry (according to Selectbikes.com):
Wheelbase: 1020mm
Chainstay Length: 362mm
BB Rise: 60mm
Head Angle: 71.5 degrees
Weight: Around 9.3 / 9.5 kg
Edited by Zoo!Man
