Old Onza Zoot
VOLTAGE25
yes gears is normal but most people use single speed now because its alot lighter and looks better in my opinion, from what i know the old zoot frames are prety good, they have the same geometry as the first inspired fourplay i think and from what i would guess there a prety solid frame, i havnt realy heard bad things about onza frames, if you do buy it though, the first thing you might want to do if it hasnt already got them changed a new set of pads, good ones like rockmans, tnn or heatsink and maybe a grind on your rim and then making it single speed if you have the money.
hope this helps
chris
They're alright.
Had one for about a year. Bombproof, but heavy.
Sits between trials and street as a decent compromise, but as a result it's difficult to go really far in either area.
Good if you're not sure which side of trials you prefer/like both - but I took a liking to the hoppy side of trials and it wasn't too great at that.
