monty221ti Posted January 5, 2011 Report Share Posted January 5, 2011 hi guys, i have got a tr wheel for my brothers bike, the bike is a monty 221 ti from 2006, and the wheel is, Tr rim on Tr hub 2010, but when i put the wheel on it dont fit, the dics is pulled very much to the left, against the frame and i have to turn my cog around, anyone tried this or someone there can tell me what to do so it fits good? thanks Erik Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 5, 2011 Report Share Posted January 5, 2011 Monty frames have 110mm hub spacing, the hub is designed for 116mm just like all modern frames. The lack of snail cams between the hub and frame effectively mean that while you can get the wheel in easily, you're missing 3mm worth of spacers on each side. There's little you can do about this without cracking the frame in due course. Quote Link to comment Share on other sites More sharing options...
monty221ti Posted January 6, 2011 Author Report Share Posted January 6, 2011 what can i do? i am using snail cams on the outside of the frame. Quote Link to comment Share on other sites More sharing options...
trials owns Posted January 6, 2011 Report Share Posted January 6, 2011 the tr hub without the snail cams and the standard washer make it 110mm spacing, i though it only made it 116mm spacing with the snail cams inside. Quote Link to comment Share on other sites More sharing options...
monty221ti Posted January 6, 2011 Author Report Share Posted January 6, 2011 what if i take the washers and file them a little bit down so it will fit? can i do that? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted January 6, 2011 Report Share Posted January 6, 2011 Put the disc side snail cam between the hub and the frame, and the drive side snail cam on the outside of the frame. That way, you will only have to stretch the frame out a very small amount, the disc rotor will be in the correct alignment, and you won't have to go around bodging anything Quote Link to comment Share on other sites More sharing options...
monty221ti Posted January 6, 2011 Author Report Share Posted January 6, 2011 i have to stretch the frame a little bit when both snailcams are on the outside. Quote Link to comment Share on other sites More sharing options...
Stefkeeee Posted January 6, 2011 Report Share Posted January 6, 2011 On 1/6/2011 at 10:28 AM, monty221ti said: what if i take the washers and file them a little bit down so it will fit? can i do that? Okee but what if you're riding with chaintugs? I have the same setup as him but I am riding the onza comp frame and there's no space for a disc. Can you help me please? BTW the Echo TR hub has two different spacers(one small and one thicker spacer). Quote Link to comment Share on other sites More sharing options...
monty221ti Posted January 6, 2011 Author Report Share Posted January 6, 2011 i will make the bike brakeless to it wont be a problem:) thanks anyways guys!!! Quote Link to comment Share on other sites More sharing options...
