cunny12345 Posted January 5, 2011 Report Share Posted January 5, 2011 Hi, i have got a very slow piston on my back magura and it is stuck out about half the way but i just wanted to know if anybody has any suggestions on what to do thanks matt. Quote Link to comment Share on other sites More sharing options...
trials owns Posted January 5, 2011 Report Share Posted January 5, 2011 pull piston out and put some lube of some sort on and pump it a few time via the lever. that should help it Quote Link to comment Share on other sites More sharing options...
cunny12345 Posted January 5, 2011 Author Report Share Posted January 5, 2011 ok thanks mate Quote Link to comment Share on other sites More sharing options...
pezza p Posted January 13, 2011 Report Share Posted January 13, 2011 Hold the piston that's stuck out and press the lever then do the same on the other side after that put some oil on the piston and do the same thing again Quote Link to comment Share on other sites More sharing options...
JT! Posted January 13, 2011 Report Share Posted January 13, 2011 First thing you should always try is undo the TPA on the lever and see if that solves the problem. If it does (which is most likely will) re-set up your magura of the pistons and physically closer to the rim. Quote Link to comment Share on other sites More sharing options...
paterson Posted January 19, 2011 Report Share Posted January 19, 2011 i filled a small pot up (lid of aresole can) with engine oil left it in the for about half hour pushed piston in slowly them worked it in and out cleaned of using brake cleaner been fine since Quote Link to comment Share on other sites More sharing options...
