Greetings Posted January 4, 2011 Report Share Posted January 4, 2011 Some time ago I stripped the thread on the non drive side Reset bb cup. Was using a steel replacement from a square taper VP but found today that the play in the BB was in fact wear of the steel cup and not the bearings. It was never a tight fit either which is probably why more play appeared throughout the course of the year. Since cups are going to be pretty hard to come by, can somebody recommend a cheap BB with an aluminium cup matching the parameters of the Reset one? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted January 4, 2011 Report Share Posted January 4, 2011 Are they the same as the Try-All ones? Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 4, 2011 Author Report Share Posted January 4, 2011 Not that I'd consider a TA cheap but to answer your question, I don't know Here's the problem, the stop on the VP cup is in the wrong place leaving a gap between the bearing and cup. I could have a spacer made, but since this bb is fairly high quality stuff, I wouldn't like to bodge it. Quote Link to comment Share on other sites More sharing options...
Jon Alty Posted January 4, 2011 Report Share Posted January 4, 2011 http://www.tartybikes.co.uk/bb_spares/reset_bottom_bracket_cup/c103p11321.html Theyre out of stock atm but says they are on order. They are pretty cheap though considering the BB is like £100. Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 4, 2011 Report Share Posted January 4, 2011 to answer your question, I don't know They do. Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 5, 2011 Author Report Share Posted January 5, 2011 (edited) http://www.tartybikes.co.uk/bb_spares/reset_bottom_bracket_cup/c103p11321.html Theyre out of stock atm but says they are on order. They are pretty cheap though considering the BB is like £100. Cheers, wasn't aware that these are available as spares! edit: Mark, since you'll be looking, doesn't the Reset bb come with Ti bolts rather than steel ones? Edited January 5, 2011 by Greetings Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 5, 2011 Report Share Posted January 5, 2011 Just steel, I thought... Quote Link to comment Share on other sites More sharing options...
