Plymouthtrials Posted January 2, 2011 Report Share Posted January 2, 2011 Hey everyone, does anyone know if you can bleed the echo hs33 with water, and stil work fine? Obviously you can bleed the standard magura with water! Cheers! Quote Link to comment Share on other sites More sharing options...
SamKidney Posted January 2, 2011 Report Share Posted January 2, 2011 I wouldnt. Get your self some phat phluid and bleed it. Water based, non corrosive and great feel. 10 quid. Win Quote Link to comment Share on other sites More sharing options...
Sam T Posted January 2, 2011 Report Share Posted January 2, 2011 Hey everyone, does anyone know if you can bleed the echo hs33 with water, and stil work fine? Obviously you can bleed the standard magura with water! Cheers! I wouldnt. Get phat phluid. . Water based, non corrosive and great feel. 10 quid. Win Quote Link to comment Share on other sites More sharing options...
SamKidney Posted January 2, 2011 Report Share Posted January 2, 2011 (edited) -+ PHLUID £10.00AboutDeliveryReturnsPHLUID: the all year round performance hydraulic rim-brake fluid. First developed early in 2008, we saw the need for a consistently high performing brake-fluid that gave a sharp, responsive feel at the lever. Phluid was designed to be used by riders to eliminate freezing in the winter, whilst putting a stop to corrosion of internal components all year round. Phluid comes in a slim, 300ml, recyclable aluminium bottle; perfect for carrying around on a ride or in your workshop. - Highly responsive lever feel; light and snappy - Water-based - Solid performance all the way to -10°C - Corrosion inhibiting, eliminating damage to internal components - Non-toxic Edited January 2, 2011 by Echo Lite 09 Quote Link to comment Share on other sites More sharing options...
