Rear Wheel Hoping
PeterWest
watch a view training videos like ryan leech, then practise putting your front wheel on a ledge and jumping the bike up and down, to get the feel of being on the back wheel but not having to hold the front wheel up, then take it from there jumping away from the ledge hanging your front wheel in the air and with practise it will become easier.
I learnt the oldskool Martins way by riding along slowly, pop an endo and as your rear wheel comes back down lean back onto it to start hopping. And then I just practised at it trying to do as many as I could without dropping the front wheel, eventually it became second nature though this was 10 years ago so there may be some better ways to learn by now.
As above, do it from an endo first! Easiest way to get the feel of things and where the balance point of your bike is. The hard bit is moving around, for that you need to drop your front wheel a little - that held me back for AGES when i was first starting out.
ages, few things worth learning; being able to kick your pedals and bring your weight back at the same time so the bike rolls onto the back wheel, it's smoother and you usually have more control with it. next when your ok sitting on the back wheel, try letting go of the back brake and stabbing the pedal a little bit so the bike rolls along, before it whips out, lock up the brake to stop it, rinse and repeat... then when your confident with that add a jump to the motion and you'll be laughing, it sounds easy, but it's not, eventually it clicks and feels like second nature though :D
i to posted loads of times asking this question and no matter how many times people gave me tips or which videos i watched they never helped
i basically went out every day for a month and practiced. start from an endo and get on the back wheel
easiest way i found to do it was.
endo then rock onto back wheel a few times
then endo and rock to back wheel and bounce once a few times
then endo and rock to back wheel and bounce twice a few times
you get the picture.
when i was just trying to bounce like the guys in videos on here it just didnt work. the tutorials i found on the net make it look simple but i know how frustrating it is when you just cant do it
I did it the endo way in just over an hour. The pedal kick method took me a week or so to do. I'm one of those people that can "just do things" although I'm never really any good at it :P
A year on (I ride maybe once every 4-5weeks) I can barely sidehop, I can up to rear and pigeon ok though.
Think back hops took me a week or two.
I used the endo method.
Pedal kicks were much harder, I tried kicking to back wheel and then kicking some more, as wel as straight kicking from a back hop but after a while I switched to the wheelie-stop method and learnt it.
This is exactly the problem when noobs don't take the time to learn the basics (trackstand all 4 ways, then without brakes, being able to balance on different heights, etc.) is the rear wheel is a huge problem. Nearly every person who learns to get balance down first, then and only then, try to get on the back wheel NEVER have problems. The 2 people I've told to learn this way after a month of getting basics down tried to get on the back wheel and it was nearly second nature (which btw, is what I preached when learning). The balance on the rear wheel could be learned within an hour if the balance has a solid foundation to rest upon.
It's not just balance, but it's complete awareness of what different situations and weight distributions are like and knowing how to correct it to regain/keep balance. As soon as somebody can learn to know how to handle balancing skills, the rear wheel is easy. Problem is, noobs are so anxious to hop on the rear they end up with a shitty foundation of core skills, then have bad habits, and a year or two down the road are having one hell of a time breaking those habits. Learning properly, in the long run is usually much faster in progression of new skills as there are no/very little bad habits to correct in the process. Like anything learned, if learned properly, it's usually much more fun and far less frustrating.
Anybody who plays a musical instrument can relate. You can jump head first into learning your favorite song and be good at that, but absolutely suck at everything else because you didn't take the time to learn the fundamentals. And the person who did learn the fundamentals after a year is far, far better in every aspect and learning new material isn't nearly as painful...
+1 that is an awesome reply.
Doh.
