cunny12345 Posted December 30, 2010 Report Share Posted December 30, 2010 Hi, i have just recently bought some echo sl cylinder washers to go on my standard magura brake clamps, but i put them on with the original plastic washers and tighten them up the little taps on the mount does not touch the other mount as i dont want to tighten the bolts any more as they are very tight now, are the tabs sapppost to hit the other mount or is it ok if i leave it so the tabs are not touching the other mount thanks matt. Quote Link to comment Share on other sites More sharing options...
Jake Beach Posted December 30, 2010 Report Share Posted December 30, 2010 May be wrong, but arnt they meant to replace the plastic washers? Quote Link to comment Share on other sites More sharing options...
cunny12345 Posted December 30, 2010 Author Report Share Posted December 30, 2010 cant be because when i only have the metal washers i tighten up the bolts tight and the slave cilinder can move around Quote Link to comment Share on other sites More sharing options...
Jon Alty Posted December 30, 2010 Report Share Posted December 30, 2010 May be wrong, but arnt they meant to replace the plastic washers? I dont think so, i think thats just if u got SL clamps too, i think with normal maggy clamps u need the washer. I dont really understand what u mean, but i think u mean each half of the mount arent touching each other, as though the cylinder is too big for the clamps? I guess if this is the case, then aslong as they are tight + u have it all square (same space between halfs on both side) then i guess it should be ok? Dont over tighten it though as u might strip the thread in your frame, which is bad times . Quote Link to comment Share on other sites More sharing options...
cunny12345 Posted December 30, 2010 Author Report Share Posted December 30, 2010 I mean the little tab on the side of each mount so when you tighten up the bolts the litle tab on the side hits the bottom mount and i just wanted to know if the tab hast to hit the other mount as mine doesnt, if you get what i mean Quote Link to comment Share on other sites More sharing options...
davidbarr Posted December 30, 2010 Report Share Posted December 30, 2010 I mean the little tab on the side of each mount so when you tighten up the bolts the litle tab on the side hits the bottom mount and i just wanted to know if the tab hast to hit the other mount as mine doesnt, if you get what i mean As long as your clamps are tight, then i guess it's fine. Quote Link to comment Share on other sites More sharing options...
multi tasking male Posted December 30, 2010 Report Share Posted December 30, 2010 i know what you meen, its ment to sit flat, it sounds like you might have the clamps upside down so there not sitting into the frame properly, try taking the clamps off and turning them the other way, see if it works. look at some pictures on google images or of bikes on here and see what they look like and just compare yours with it, like spot the difference hope i helped chris. Quote Link to comment Share on other sites More sharing options...
George.E Posted December 30, 2010 Report Share Posted December 30, 2010 Just grind the little tabs off then you will have room to tighten? Quote Link to comment Share on other sites More sharing options...
cunny12345 Posted December 31, 2010 Author Report Share Posted December 31, 2010 Yeh i get what you mean, when i put both of the washers on is it sappost to be really hard to push the mounts down and tighten up the bolts as my plastic washer is all mangled and lob sided in the mount but my pads are all set up square. Quote Link to comment Share on other sites More sharing options...
