Top Cap Problem!
davidbarr
erm then take your forks off and try and tap the star nut out the other way, or maybe try and lever the top cap off with a screw driver if you can. Do you have alot of of spacers under your stem it might be because there isn't enough thread contact with you top cap bolt and star nut just so you don't do it again.
I've just got one spacer on. Guess i'll have to lever the cap off then. The forks won't come with it still on.
erm then take your forks off and try and tap the star nut out the other way.
Don't comment on stuff you haven't even thought about before you post.... if you cant get the star nut out how can he get his forks off? durrr
If your lucky then you can take your front wheel out, and fit a small metal pipe (like an allen key or somthing) up the forks and then hammer the shit out the star nut to push it up the forks, it takes some propper welly so dont f**k about with it.
Or Grind off your top cap.
The 1st option has worked for me a couple of times before.
Thanks for the comment. :)
That was a momentary lasp of concentration and I' am truly sorry but I did say the same thing as you so don't get so annoyed, but that proberly will damaged the forks abit.
