Greetings Posted December 30, 2010 Report Share Posted December 30, 2010 Spent the last 3 months creating a spec for my next bike, got pretty much everything dialled apart from the stem. Has anyone compared a 138x25 Echo SL stem side by side with a TryAll 150x30 stem? I'm looking for something slightly longer but with a bar clamp height no more than 10mm greater than the Echo. Quote Link to comment Share on other sites More sharing options...
robintrial Posted December 30, 2010 Report Share Posted December 30, 2010 i have the try-all stem and it is the best i had ever had it's not heavy and gives more clearence then a normal stem hope this helps robin Quote Link to comment Share on other sites More sharing options...
Greetings Posted December 30, 2010 Author Report Share Posted December 30, 2010 Anyone? Quote Link to comment Share on other sites More sharing options...
cai Posted December 31, 2010 Report Share Posted December 31, 2010 (edited) I haven't compared these stems side by side or anything, but this always helps me when deciding on stems: ..I find it pretty useful for comparing stem hights/lengths etc.. EDIT: Have you considered the Monty PR stem? Its only £15, pretty light at 209 grams, and measures up at 150 x 25°.. Bad news is its currently on order Otherwise theres the V!Z Welded stem which is £39 and 207 grams and also 150 x 25°.. Edited December 31, 2010 by cai Quote Link to comment Share on other sites More sharing options...
Greetings Posted December 31, 2010 Author Report Share Posted December 31, 2010 (edited) Cheers, that diagram is actually quite helpful As for the stems you mentioned, yes the Viz or Monty would probably be ideal but the Viz is only available in white and the PR is out of stock. The 2011 Viz stem has the geometry of the TryAll/Rockman which I'm not sure would suit me, especially after looking at that pic you posted. edit: rough measurements Echo SL 138x25 - 58mm rise and 125mm reach TryAll 150x30 - 74mm rise and 129mm reach Monty PR / Viz - 62mm rise and 135mm reach So yeah, the Monty sounds pretty much perfect whereas the Tryall is out of the question. Edited December 31, 2010 by Greetings Quote Link to comment Share on other sites More sharing options...
Jon Alty Posted December 31, 2010 Report Share Posted December 31, 2010 u say slightly longer than 150mm, the 221 kamel is 175x30, and i think the rise is 14mm but ill check on tarty, and when u say no more than 10mm higher than the echo, arent the echo TR like +25 already which is pretty high? If you ride mod then these are good, but maybe a bit longer than what your looking for? Quote Link to comment Share on other sites More sharing options...
cai Posted January 1, 2011 Report Share Posted January 1, 2011 Cheers, that diagram is actually quite helpful As for the stems you mentioned, yes the Viz or Monty would probably be ideal but the Viz is only available in white and the PR is out of stock. No problem man. If I were you I'd contact TartyBikes when they're open again and ask when the PR will be back in stock (..or if it ever will again?). If all else fails I wouldn't let the colour of the Viz stem put you off, after all with some paint stripper and polish it could easilly be made silver along with it then being a tad lighter or theres always a spray can if your stuck on having a black stem. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted January 1, 2011 Report Share Posted January 1, 2011 Why are stems measurement not shown in reach and rise rather than angle and length? It sucks. Quote Link to comment Share on other sites More sharing options...
cai Posted January 1, 2011 Report Share Posted January 1, 2011 It'd be awsome Matt! Maybe TartyBikes could incorparate this idea into there product pages, just like how they have worked out the height and width of tyres. Quote Link to comment Share on other sites More sharing options...
Hessy Posted January 1, 2011 Report Share Posted January 1, 2011 (edited) This is a very good application which shows you comparisons of your chosen stems. Stem calculator Jed Edited January 1, 2011 by Hessy Quote Link to comment Share on other sites More sharing options...
cai Posted January 1, 2011 Report Share Posted January 1, 2011 Stem calculator That is much more useful than my little graph Quote Link to comment Share on other sites More sharing options...
