Is My Hub Broken? Or On Its Way Out
Sheffield noob
hi everyone.
basically i have just recieved a monty 221 front disc hub off a member on here and...
when you turn it, its not smooth u can feel the barings inside.. like a rough feeling. like you can feel everything inside working...
i have the feeling that when i make up the front wheel its barely guna spin or if it does it wownt spin for long like my rear one does...
does this sound familiar??
Liam
Common problem with sealed bearings after having them. Its due to the grease inside the bearings itself wearing away leaving you with a bearing feeling horrible and rough. If you go to your local bike shop ( preferably not halfords, clueless ) they usually have some new ones. If you want to keep the ones you have, all I did was put prolink ( I'm sure any other lubricant will be fine, tf2, wd40 ect ) and soak it! Hope this helps.
  • 2 weeks later...
To the poster above, WD40 is a de-greaser not a lube.
actually it's not a de-greaser common misconception, It is a lubricant but not a heavy one. It is more of a rust inhibitor that anything.
the question you should ask yourself is after i spray that on a bike part and let it dry when it touch it is it slippery?
To be fair it is a bit of both. Technically it is a highly penetrating lubricant that is (reasonably) easily removed with water. While it is a lubricant it does in fact have the same affect as a degreaser if used a permanent lubricant in the sense that a degreaser removes the old grease and then allows it to be easily washed away.
Edited by sstein
