onza1 Posted December 28, 2010 Report Share Posted December 28, 2010 Hi I own a onza rip and think it's time for new pads know £40 is my limit do I just buy standard v pads and booster off chain reaction for about £15 and then so the front aswell or some heatsinks an no booster or diff pads diff booster upgrade to mag also I have a idea on running a disc on the back, and last of all are 19" rear wheels an advantage? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Sam T Posted December 28, 2010 Report Share Posted December 28, 2010 Hi I own a onza rip and think it's time for new pads know £40 is my limit do I just buy standard v pads and booster off chain reaction for about £15 and then so the front aswell or some heatsinks an no booster or diff pads diff booster upgrade to mag also I have a idea on running a disc on the back, and last of all are 19" rear wheels an advantage? Thanks in advance Please, re-type that will fullstops. Alomost died.. An attempt to answer your questions Don't buy standard black pads, they're crap. Instead a set of Inspired pads. There very soft compound makes them awesome on smooth + ground rims. Defo' get a rear booster, it'll stiffen your brake and lever feel alot! Wouldnt upgrade to a Magura unless you have proper 4 bolt frame. Personally them adapters are a absolute b**ch to set up. Theres nothing wrong with a decent rear V set up, i.e: Deore arms, Tnn Lgv pads, grind and Shimano xtr lever. With the 19" rear wheel, advantages of that would be due to the thickness of it, it can make life alot easier staying on the back wheel, gapping ( dont 'rim' out ) Hope this helps.. Quote Link to comment Share on other sites More sharing options...
onza1 Posted December 28, 2010 Author Report Share Posted December 28, 2010 Cheers mate. So shall I get the inspired pads or the heatsinks?About the rear wheel do you know where I can get a 19" with disc hub for around £50 for a experiment. Plus do you need somert special on the frame to run a rear disc ? With them pads shall I grind the rim. And would you recemoned a lubed brake cable. And how's that for full stops....... Quote Link to comment Share on other sites More sharing options...
Sam T Posted December 28, 2010 Report Share Posted December 28, 2010 Cheers mate. So shall I get the inspired pads or the heatsinks?About the rear wheel do you know where I can get a 19" with disc hub for around £50 for a experiment. Plus do you need somert special on the frame to run a rear disc ? With them pads shall I grind the rim. And would you recemoned a lubed brake cable. And how's that for full stops....... I'd go for the Heatsink V pads. Will be alot stiffer! Not sure if you could get a 19" wheel with a disk mount for 50, as disk hubs are usually more money. You need a disk tab on a frame. If you dont have one, then you obviously cant run a disk brake. If you end up with Heatsink yellow V brake pads, grind the rim to a sharp medium surface for best performance. I have lubed my front V brake cable, aswell as having a linear outer. Go for it. Quote Link to comment Share on other sites More sharing options...
onza1 Posted December 28, 2010 Author Report Share Posted December 28, 2010 Cheers Quote Link to comment Share on other sites More sharing options...
Blake Posted December 29, 2010 Report Share Posted December 29, 2010 Also you can't have a 19" rear wheel on an onza rip. It doesn't fit, and as far as i'm aware you cant' run a disk on an onza rip either. . . . Sorry Also you can't have a 19" rear wheel on an onza rip. It doesn't fit, and as far as i'm aware you cant' run a disk on an onza rip either. . . . Sorry Quote Link to comment Share on other sites More sharing options...
onza1 Posted December 29, 2010 Author Report Share Posted December 29, 2010 (edited) Wasn't for the rip mate. I think the rip shall get new cable and a booster for now then maybe some pads in time Edited December 29, 2010 by onza1 Quote Link to comment Share on other sites More sharing options...
