Noble biker Posted December 28, 2010 Report Share Posted December 28, 2010 I got an onza blade for Christmas I have set up the disk brake but it still rubs on the left a bit any suggestions will be helpful. thanks. Quote Link to comment Share on other sites More sharing options...
liam n Posted December 28, 2010 Report Share Posted December 28, 2010 I got an onza blade for Christmas I have set up the disk brake but it still rubs on the left a bit any suggestions will be helpful. thanks. dont worry about it if it works as a brake it's fine once the brake has bed in the rubbing should go ..... or use and adjustable spanner to bend the disc so it no longer rubs Quote Link to comment Share on other sites More sharing options...
davey1991 Posted December 29, 2010 Report Share Posted December 29, 2010 dont worry about it if it works as a brake it's fine once the brake has bed in the rubbing should go ..... or use and adjustable spanner to bend the disc so it no longer rubs Are you crazy? The calliper just needs centering on the rotor. Fiddle with the calliper until it sits nicely centred with no rub. Quote Link to comment Share on other sites More sharing options...
