Disc Or Magura?
Onza boy 2010
i like the feel of the disc so i will probably keep it for a bit then get a magura and get a grind. :) whats got a stronger hold?
depends on how good each brake is
i got a pro last year and i kept my disc for 3 months till i got good then changed it to magura and grind :D
It depends really, do you ride natural? If you ride more natural than you do TGS, as it is referred to, it'd probably be better having disks. Not that i have anything to justify them being better for natural its just i usually see the majority of natural riders using double disk and TGS riders having a front disk and rear HS33 set up. Hope that helps (Y)
Off Topic,I don't think I've been out in Leicester when you've been there, but if you ride natural^ there is a good little spot for motor trials outside Leicester off the M69 toward Nuneaton, push bikes are allowed in free, its only 10-15mins from the centre of town, let me know if you ever fancy heading down, can arrange a ride.
