Halo Reach Questions
t-comp-kierz
You can adjust your armour, which is kind of pointless and you can play in different gametypes. Aside from changing the gametype you're limited to the same weapons/upgrades as everyone else on the specific map and you'll have to pick the good guns up from wherever they spawn.
You can build things in the level editor, called Forge. It's pretty easy and you can access it from the main menu above the theatre option.
Just got Reach too. Pretty blown away, Bungie didn't disappoint with another one, again.
You do have the option when respawning to choose what sort of soldier you want to be. You have jet pack, sprint, shield etc. Also some of the weapons are different depending on if you're Spartan or Elite and i guess what game type.
In short, no you can't create classes, you have a couple of choices of preset 'classes' for you. As for creating maps, Forge is what you want.
If anyone wants to party up sometime let me know, I pretty much only play the MLG gametype though. DMR *** :)
You can learn me some skills then. I'm real bad at Halo currently :giggle:
Aye there's a rank system, you go up by name rather then numbers. So lowest rank is recruit I think then you work your way up through sergeant, warrant officer, captain, commander and loads of ranks in between. I'm warrant officer grade 3 at the moment I think, but not far off hitting captain and getting another achievement :)
I think there are 3 or 4 maps all directly moved from halo 2, just as you said with different weapon spawns.
So you mean the useless COD rank system!? Why on earth did they do that. A plain number upto 50 with highs and lows worked perfect.
