Rockman Posted December 26, 2010 Report Share Posted December 26, 2010 cant figure it out :$ I have the Try All Disc Brake with the 180mm rotor, I was told to buy the Hope ISO adaptor +20mount, now I've came to put it together and I cant figure out which way the adaptor goes will upload picture if anyone wants more info Thanks Shane Quote Link to comment Share on other sites More sharing options...
Jon Alty Posted December 26, 2010 Report Share Posted December 26, 2010 I thought the hope mount things only do ISO to ISO, so you can use a bigger rotor, but dont Try-all use their own mounting system or something? Im probably wrong so wait for someone who knows what theyre talking about to confirm Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted December 26, 2010 Report Share Posted December 26, 2010 cant figure it out :$ I have the Try All Disc Brake with the 180mm rotor, I was told to buy the Hope ISO adaptor +20mount, now I've came to put it together and I cant figure out which way the adaptor goes will upload picture if anyone wants more info Thanks Shane Put it one way and if it doesn't fit put it the other way. 1 Quote Link to comment Share on other sites More sharing options...
TrialsMan Dan Posted December 26, 2010 Report Share Posted December 26, 2010 Usually the longer bit goes at the bottom, but pics would help try explain what you're on about. Quote Link to comment Share on other sites More sharing options...
Rockman Posted December 26, 2010 Author Report Share Posted December 26, 2010 this is the only way I can find how to fit it barely any of the pad touches the rotor tryed to show how much pad is touching the rotor Quote Link to comment Share on other sites More sharing options...
craigjames Posted December 26, 2010 Report Share Posted December 26, 2010 It's the wrong way around. The writing on the mount (HBIS20) should be facing out and it should be the other way up (so the larger section is at the top). Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 26, 2010 Report Share Posted December 26, 2010 It's the wrong way around. The writing on the mount (HBIS20) should be facing out and it should be the other way up (so the larger section is at the top). I concur. The bolts into the fork should go in just the same as if it were going straight in the caliper. Quote Link to comment Share on other sites More sharing options...
Rockman Posted December 26, 2010 Author Report Share Posted December 26, 2010 I concur. The bolts into the fork should go in just the same as if it were going straight in the caliper. A woooopsy :L I will sort it tommorow Quote Link to comment Share on other sites More sharing options...
Maladie Posted December 27, 2010 Report Share Posted December 27, 2010 A woooopsy :L I will sort it tommorow I hope iso Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 27, 2010 Report Share Posted December 27, 2010 I hope iso that, was not even remotely funny, sir. Quote Link to comment Share on other sites More sharing options...
Rockman Posted December 27, 2010 Author Report Share Posted December 27, 2010 It doesn't work there is no threads when I turn it so the HBIS20 is facing me, so it doesn't lock together, if that makes sense Quote Link to comment Share on other sites More sharing options...
craigjames Posted December 27, 2010 Report Share Posted December 27, 2010 (edited) See the threads in the bottom holes on the pic? Thats the way it should go up. With the "H" at the top, and the threaded holes going on the inside of the disc mount. Seriously dude there's only so many ways it can attach to the bike and only one of them works..... trial and error. Edited December 27, 2010 by craigjames Quote Link to comment Share on other sites More sharing options...
Rockman Posted December 27, 2010 Author Report Share Posted December 27, 2010 See the threads in the bottom holes on the pic? Thats the way it should go up. With the "H" at the top, and the threaded holes going on the inside of the disc mount. Seriously dude there's only so many ways it can attach to the bike and only one of them works..... trial and error. okay, thanks. Quote Link to comment Share on other sites More sharing options...
