Best Mod Tyres?
Blake
Heya, considering getting new tyres for my t-pro as my bike came with tyres that are a little bit too worn down and I fear they wont hold too much grip for very long.
Considering an upgrade so what is everyones favourite and why?
Cheers.
On the rear I like creepy crawlers, very good grip on wet, can run very low psi and not get punctures. Plus they last for ages!
On the front I'm running a kenda small block 8 2.1". Its oriteeee I guess, in the wet though its terrible, no grip at all and I don't feel safe with it. On dry though you can run super low pressures and its great. When I mean low pressures I mean I can actually push right through from the outside to the drilled bit on my rim. I would get it for its cheapness and durability but I'm deffo gonna get aa creepy cvrawler on front after as its less of a BMXy tyre that I feel the kenda small block 8 is. :)
Small block eight on front and stiky on rear, ive tried dual crawlers, dual stikys and one of each with the block eight, and stiky and block eight was my favourite as like what dan said, you can run uber low pressure on the small block eight, and i just love stikys anyway :P
Edited by dirt jumper jake
  • Like 1
I used to run a creepy crawler on the rear and found that it wore better than the eagle claw tyre, but I would go with the Monty eagle claw all the way. The try-all wears down far too quickly, especially when you ride on concrete and tarmac. The eagle claw is the perfect compromise.
For the front definately Kenda small block - the middle sized one - 1.95".
Cheers.
I'd say either Kenda or TryAll front, and Creepy on the rear
Also out of interest who did you get the TPro off? Or is it sprayed?
Got the T-Pro of rab something. Robert Stropshire I think his name is, it's sprayed black with red/orange stars on it. . . . .and they tyres are monty with white lines by the sidewall, anyone know what they are?
Creepy crawlers or sticky lites are the best on the rear. Every one says the stickys are amazing but ive never rode one. As for creepy crawlers, they are amazing. I went from a bald creepy crawler to a new echo and i could really tell the difference. The echos are shit. Do NOT get them, everyone will tell you that.
As for the front i have rode creepy crawlers, monty and the kenda and i do like the kenda the best.
