Gaz96 Posted December 24, 2010 Report Share Posted December 24, 2010 I fit my rubber grips by putting them in boiling water so they expand, slide them on and then cool them down and they sit nice, but would this work with foam? or are different techniques used? Quote Link to comment Share on other sites More sharing options...
dann2707 Posted December 24, 2010 Report Share Posted December 24, 2010 Hair spray, spray on the inside of the grip and the bar, slide on quickly and let dry. Job is a good 'n 2 Quote Link to comment Share on other sites More sharing options...
Sam Styles Posted December 24, 2010 Report Share Posted December 24, 2010 maybe try using the search bar? there have been a few threads about the same thing within the past week... 1 Quote Link to comment Share on other sites More sharing options...
N.Wood Posted December 24, 2010 Report Share Posted December 24, 2010 I used to use foam grips like 5 years ago, been using rubber ones up until today... Jesus I hate the way they feel Anyways mine went on with a bit of gt85 and a trackpump. I wouldn't recommend this, they slipped around a fair bit today. Quote Link to comment Share on other sites More sharing options...
Gaz96 Posted December 24, 2010 Author Report Share Posted December 24, 2010 maybe try using the search bar? there have been a few threads about the same thing within the past week... No matter what I type in the search bar, no results come up. Dont know whats up with my computer. Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted December 25, 2010 Report Share Posted December 25, 2010 Hair spray, spray on the inside of the grip and the bar, slide on quickly and let dry. Thats how to do it Quote Link to comment Share on other sites More sharing options...
Shaun H Posted December 25, 2010 Report Share Posted December 25, 2010 Track pump and a football valve fitment got mine on, didn't use any lubrication and they haven't moved in the 9 months+ they've been on. Quote Link to comment Share on other sites More sharing options...
charliemod Posted December 25, 2010 Report Share Posted December 25, 2010 (edited) I just tap the end of the grip on to the bars with the palm of my hand whilst gently holding the part of the grip that isn't yet on? Works good enough for me but may take some time, but then it wont slip when you come to riding your bike Hope I helped If that fails, I would use hairspray. Edited December 25, 2010 by charliemod Quote Link to comment Share on other sites More sharing options...
Cresswell_d Posted December 26, 2010 Report Share Posted December 26, 2010 I just get a small allen key and prise the grip wide a bit then, I spray some Lynx deodorant in the gap. Then wiggle/pull it off. Then to put the grip back on, Spray the bar with deodorant then wiggle it on. Please make sure you spray enough on both sides if not it won't work. I've been doing this tip for years (it even works with rubber grips) Daz. Quote Link to comment Share on other sites More sharing options...
Tom Canham Posted December 26, 2010 Report Share Posted December 26, 2010 Hair spray, spray on the inside of the grip and the bar, slide on quickly and let dry. Job is a good 'n Ive always done this. With rubber grips and foam. And if done right, they wont slip at all. Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted December 27, 2010 Report Share Posted December 27, 2010 hairspray and speed! They dry rapid quick so you need to slide them on fast. Quote Link to comment Share on other sites More sharing options...
davey1991 Posted December 27, 2010 Report Share Posted December 27, 2010 I've always used water.. Why does no one else use water.. lol Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 27, 2010 Report Share Posted December 27, 2010 Because it takes way longer to dry, and doesn't 'hold' grips as well. I've found with certain grip and bar combos that putting them on dry didn't really work too well in terms of getting throttle-grip loads. I've got black Trialtech bars, and Halfords Satin Black paint is exactly the same colour/finish as them, so I just use that. Properly locks grips in place even if they get wet. Usually have to slice them off with a Stanley knife to get them off again, so if you need to take your grips on and off for whatever reason it might not be ideal for you... Quote Link to comment Share on other sites More sharing options...
monty-james Posted December 27, 2010 Report Share Posted December 27, 2010 Everytime ive used hairspray rain washes it out and my grib turns into a throttle. I tend to file across the end of my bars lightly and put a bit of grip glue on the inside of the grip and slide it on. I doubt many people will want to file their bars though.... Quote Link to comment Share on other sites More sharing options...
davey1991 Posted December 28, 2010 Report Share Posted December 28, 2010 Because it takes way longer to dry, and doesn't 'hold' grips as well. I've found with certain grip and bar combos that putting them on dry didn't really work too well in terms of getting throttle-grip loads. I've got black Trialtech bars, and Halfords Satin Black paint is exactly the same colour/finish as them, so I just use that. Properly locks grips in place even if they get wet. Usually have to slice them off with a Stanley knife to get them off again, so if you need to take your grips on and off for whatever reason it might not be ideal for you... Hmm ok, I don't use any of these new fangled foam grips, I buy lengths of road bike bar foam which i much prefer so maybe thats it. Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 28, 2010 Report Share Posted December 28, 2010 I just use the fact that I'm a man and simply pull and twist the grip on. Yeah, I usually do with rubber grips but I've found a few types of foam grip seem to not really stick all that well if you put them on dry. Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted December 28, 2010 Report Share Posted December 28, 2010 I just use the fact that I'm a man and simply pull and twist the grip on. same, always have dunno whats with all the arse'in about Quote Link to comment Share on other sites More sharing options...
MontySamba Posted December 30, 2010 Report Share Posted December 30, 2010 If you are using glue to put them on, then get 5 or 6 cable ties slide them through and then the grip just slides over the bar and then you just pull the ties out before the glue dries and thats how i've done it and its quick and easy. If you have no glue then use some contact cleaner/hairspray and use the same technique. Quote Link to comment Share on other sites More sharing options...
Dušan Posted December 30, 2010 Report Share Posted December 30, 2010 i use air compressor.... put one side of the grip on the handlebar and i put the air pistol into the grip hold it so the air wont go out and make pressure on grip and its on... quite easy if u have air compressor Quote Link to comment Share on other sites More sharing options...
