Chain Cleaning
Rockman
I just cleaned my chain, I thought this way may be useful to you guys.
Take your chain off your bike
put it into a bottle
fill the bottle 1/4 with water and a bit of fairy liquid
shake it until the water is black
then repeat another time
fill again with 1/4 water and keep doing this till the water isn't dirty any more
if you have a product called "sticky stuff remover" put a few drops of that in aswell which removes oil
when you have done that lay it on a towel etc. and spray with oil
Hope this helped :)
Hope this helped :)
kool but i just washed my chain :L shane :P
Just in case you or others are not aware diesel contains one of the most carcinogenic non radioactive substances known to man.
Doesn't that mean it would have to be burnt and the carcogen would be in the fumes? So as long as you don't burn it it'll be all right?
I only say this because at school we are no longer allowed to burn crude oil or to distillate it fractionally due to the carcinogens in the fumes. :)
I don't believe so, wearing of protective gloves is a good option.
What the mother in epicness is a carcinogen
Every substance in the world ever basically, occasionally the flavour of the month carcinogen gets some bad press and people decide to get scared about it. Bearing in mind you can't do a 5 minute test of flicking it on someone and going "ooh yep, they just got cancer" unsurprisingly yes there's something of a correlation between cancer cases and people that spend a lot of time around/covered in crude oil/oil products.
And actually the most commonly found carcinogen is probably living material, being carbon based and therefore radioactive (this is how carbon dating works) it is also a carcinogen, and since there's more living things in the world than smokers... :P
take it off, take it outside and spray some gt85 or wd40 on the chain making sure you get in all the links, then scrub with a toothbrush. when the chain and excess spray turn grey-black spray it again then hang it from the washing line, letting it dry.
put it back on and use finish line xc wet lube.
