sandeeebeach219 Posted December 22, 2010 Report Share Posted December 22, 2010 Hey My chain is touching the chainstay on my Echo Lite frame and I'm not sure why? Anyone else had this problem? What can i do about it? (i was thinking of putting a washer in) Cheers. Quote Link to comment Share on other sites More sharing options...
Rockman Posted December 22, 2010 Report Share Posted December 22, 2010 Hey My chain is touching the chainstay on my Echo Lite frame and I'm not sure why? Anyone else had this problem? What can i do about it? (i was thinking of putting a washer in) Cheers. put a small rubber washer between the frame and snail cam this should move the frame out a bit, which will increase the chain clearance. Quote Link to comment Share on other sites More sharing options...
weebryan Posted December 22, 2010 Report Share Posted December 22, 2010 (edited) Had this problem on my DOB. I tried a smaller/no spacers on cog on rear hub, to move in/out , smaller/no spacers on cranks to move freewheel in/out, bottom bracket lenghts, thinner chains i eventually got the right combination , i also wouldnt recomend spreading the frame out with washer yea its a easy fix but not a good idea Tarty have spacers for hub and freewheel http://www.tartybikes.co.uk/hub_spares/tryall_sprocketfreewheel_spacer/c22p11328.html Edited December 22, 2010 by weebryan Quote Link to comment Share on other sites More sharing options...
sandeeebeach219 Posted December 22, 2010 Author Report Share Posted December 22, 2010 Had this problem on my DOB. I tried a smaller spacers on cog on rear hub, to move in/out , smaller spacers on cranks to move freewheel in/out, bottom bracket lenghts, thinner chains i eventually got the right combination , i also wouldnt recomend spreading the frame out with washer yea its a easy fix but not a good idea How is it no a good idea? Will it mess up something or...? Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 22, 2010 Report Share Posted December 22, 2010 How is it no a good idea? Will it mess up something or...? Yep, thats why monty frames crack when you run a profile as they are only designed to take a 110mm hub where profiles are 116mm... Quote Link to comment Share on other sites More sharing options...
weebryan Posted December 22, 2010 Report Share Posted December 22, 2010 (edited) Drop out wont be square onto hub, more stress on welds, wheel moves about dropout more i tried it didnt go well for me I eventually took it to a local bike shop (wheel craft) and they let me use their stand and try various bb, spacers chains got a perfect line and a gap between chain and frame was a long slow proscess but word great no wheel moving until the frame cracked Edited December 22, 2010 by weebryan Quote Link to comment Share on other sites More sharing options...
sandeeebeach219 Posted December 22, 2010 Author Report Share Posted December 22, 2010 Yep, thats why monty frames crack when you run a profile as they are only designed to take a 110mm hub where profiles are 116mm... Then how should i fix the problem? I have Echo Lite frame Trialtech screw on rear sprocket Trialtech Z610 chain Echo TR rear hub Neon Carbon Sq Taper BB Echo SL freewheel (front) Quote Link to comment Share on other sites More sharing options...
weebryan Posted December 22, 2010 Report Share Posted December 22, 2010 Then how should i fix the problem? I have Echo Lite frame Trialtech screw on rear sprocket Trialtech Z610 chain Echo TR rear hub Neon Carbon Sq Taper BB Echo SL freewheel (front) Take front freewheel off and try spacer my TI bash is enough to space it out on my rockman Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 22, 2010 Report Share Posted December 22, 2010 Then how should i fix the problem? I have Echo Lite frame Trialtech screw on rear sprocket Trialtech Z610 chain Echo TR rear hub Neon Carbon Sq Taper BB Echo SL freewheel (front) Sqaure taper BB's tend be quite narrow compared to the isis ones, well thats what ive found anyway. ideally you would solve it with a uber wide isis bb and crankset. i think it is possible to get a 127.5/128mm sqaure taper bb though? unless you allready have one.... are you running a bash ring? if not try taking the freewheel off and putting a spacer imbetween the the cranks and freewheel. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 22, 2010 Report Share Posted December 22, 2010 There is a very simple solution to this problem and I think I know what it is, I had a similar problem with my zoo lynx. Remove rear screw on sprocket. Turn it round so the bit the chain runs on is next to the wheel Replace sproket. Quote Link to comment Share on other sites More sharing options...
sandeeebeach219 Posted December 22, 2010 Author Report Share Posted December 22, 2010 (edited) There is a very simple solution to this problem and I think I know what it is, I had a similar problem with my zoo lynx. Remove rear screw on sprocket. Turn it round so the bit the chain runs on is next to the wheel Replace sproket. Will that not wreck the threads or something? More to the point, the chain would be proper squint..... Edited December 22, 2010 by sandeeebeach219 Quote Link to comment Share on other sites More sharing options...
sandeeebeach219 Posted December 22, 2010 Author Report Share Posted December 22, 2010 Is a washer between the frame and snail cam really a bad idea? I dont see how it wont work or how it will wreck the bike? Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 22, 2010 Report Share Posted December 22, 2010 Dude it works, and will not f**k the threads (how can it?) Post some pictures and we can help you better, or try it and see. Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 22, 2010 Report Share Posted December 22, 2010 Is a washer between the frame and snail cam really a bad idea? I dont see how it wont work or how it will wreck the bike? Yep, thats why monty frames crack when you run a profile as they are only designed to take a 110mm hub where profiles are 116mm... are you blind? i explained why it wont, it will make the hub setup wider than the frame allows and will eventually crack it. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 22, 2010 Report Share Posted December 22, 2010 Jake is correct, listen to people that know what they are talking abouts advice dude or just don't ask. It's not like he offered no explanation for his statement. Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 22, 2010 Report Share Posted December 22, 2010 spreading the dropouts by a couple of mill won't brake it, being a harsh rider and landing stuff sideways will (a usual trait of profile owners). Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 23, 2010 Report Share Posted December 23, 2010 being a harsh rider and landing stuff sideways will (a usual trait of profile owners). BMXers Quote Link to comment Share on other sites More sharing options...
Rich J Posted December 23, 2010 Report Share Posted December 23, 2010 Yep, thats why monty frames crack when you run a profile as they are only designed to take a 110mm hub where profiles are 116mm... Im pretty damn sure profiles are 110 spaced so thats wrong.. 1 Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 23, 2010 Report Share Posted December 23, 2010 Im pretty damn sure profiles are 110 spaced so thats wrong.. some are some arent, the one i had was 116mm when i measured it, cos i had to stretch my identiti frame to get it in aswell... Quote Link to comment Share on other sites More sharing options...
Rich J Posted December 23, 2010 Report Share Posted December 23, 2010 Identiti what? Apart from Tarty listing them as 116 nowhere I can find does. Either way slightly stretching frames is not a massive problem, but you shouldnt need to. Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 23, 2010 Report Share Posted December 23, 2010 Identiti what? P45 park frame, they take bmx rear hub... Quote Link to comment Share on other sites More sharing options...
Rich J Posted December 23, 2010 Report Share Posted December 23, 2010 Fair, yes they do but still I have never seen or heard of a 116 profile existing. Quote Link to comment Share on other sites More sharing options...
Leistonbmx Posted December 23, 2010 Report Share Posted December 23, 2010 Older profiles were 116. Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 23, 2010 Report Share Posted December 23, 2010 Older profiles were 116. Yessss point proven Quote Link to comment Share on other sites More sharing options...
rupintart Posted December 24, 2010 Report Share Posted December 24, 2010 (edited) Yep, thats why monty frames crack when you run a profile as they are only designed to take a 110mm hub where profiles are 116mm... No, no, no.....Profile, as are ALL BMX HUBS are 110mm spacing. Edited December 24, 2010 by rupintart Quote Link to comment Share on other sites More sharing options...
