Rim Grinding
alex-trials-boy
Hey guys I can't find my dads angle grinder so I was just woundering if I could use a dremmle with a stone cutter on my rim to grind it, the cutter is quite thick and is a little bigger than a 2p but would it work the rpm on the dremmle is 3000rpm I don't know flif that makes any difference? Any help appreciated,
thanks
Alex.
Sounds like it would take forever...... wait till you can grind it properly. You're fairly guaranteed that that wee dremel disc will shatter i would have thought
I've got a pack of 30 stone cutters ill do anything to improve my brake it's just soo annoying in like jan feb time I'll be getting a new rim so it do t have to be a perfict job just woundered if it was possible?
