How To Tune Your Chain Length
Alex Dark
"Adding or subtracting a link in the chain will move the axle 1/2". Changing either sprocket size by one tooth is the equivalent of moving the axle 1/8" (4 mm). Thus, if I wanted a 5.75 gain ratio (75" / 6 meter gear), I might first try a 42/15, this gives a gain ratio of 5.77 (75.6" / 6.05 m gear). If the chain was too loose, I could take up 1/8" (4 mm) of axle movement by replacing the 42 with a 43. This 43/15 combination would raise my gain ratio to 5.91 (77.4" / 6.19 m). Alternately, I could get the same axle position with a 42/16 --5.41 (70.9" / 5.67 m).
If I was not happy with these choices, I could add a link to the chain and switch to a 45/17 --5.45 (71.5" / 5.72 m) If I added two links to the chain, I could get the same axle position with a 48/18 --5.49 (72.0" / 5.76 m)"
Might help someone :)
