Rob. Posted December 21, 2010 Report Share Posted December 21, 2010 Just bought a new rim for my tryall h hub and realised my hub is a 36H instead of 32H , i really cannot be assed to spend 105pounds on another tryall hub. So is there anyway i can use my 36h as a 32h? need quick reply thank you Quote Link to comment Share on other sites More sharing options...
LordMersey Posted December 21, 2010 Report Share Posted December 21, 2010 Im sure you can, If you have a quick search im sure there is a diagram on the forum somewhere showing you what to do. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted December 21, 2010 Report Share Posted December 21, 2010 just leave two and two oposite spoke holes empty,that´s all. Quote Link to comment Share on other sites More sharing options...
JD™ Posted December 21, 2010 Report Share Posted December 21, 2010 Yea, you want 2 holes opposite each other on one flange left clear, and then 2 holes opposite on the other flange, but 90* round from the first ones, so that in effect you've got spoke holes free, and equally spaced. The other option is sending the rim back and buying one with the right amount of holes? Quote Link to comment Share on other sites More sharing options...
Rob. Posted December 21, 2010 Author Report Share Posted December 21, 2010 Yea, you want 2 holes opposite each other on one flange left clear, and then 2 holes opposite on the other flange, but 90* round from the first ones, so that in effect you've got spoke holes free, and equally spaced. The other option is sending the rim back and buying one with the right amount of holes? theres no decent 36h rims out. and with that setup you said , does the wheel look stupid? Quote Link to comment Share on other sites More sharing options...
JD™ Posted December 21, 2010 Report Share Posted December 21, 2010 Well in that case it's your only choice, so it won't really matter if it looks stupid anyway! But no, it shouldn't look too different to a normal wheel, but when I've done it I've never actually gone so far as to check it against another wheel. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted December 21, 2010 Report Share Posted December 21, 2010 theres no decent 36h rims out. and with that setup you said , does the wheel look stupid? Thats why you should send the hub back Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted December 21, 2010 Report Share Posted December 21, 2010 Thats why you should send the hub back problem is the new rim,not hub and no,the wheel looks normal and rides normal too,i haven´t noticed any difference. Quote Link to comment Share on other sites More sharing options...
Theta2 Posted December 23, 2010 Report Share Posted December 23, 2010 I have a 32h rim laced on to a 36h hub, 4 empty spoke holes, looks and works absolutely fine Quote Link to comment Share on other sites More sharing options...
