Jon Alty Posted December 20, 2010 Report Share Posted December 20, 2010 (edited) Hi, i have a Magura Marta disc brake, but has a 160mm rotor, from my mod. I want to use it on my stock and obviously 160mm rotor is just useless. Was wondering are there any disadvatages of a 200mm rotor over a 180mm rotor? Also is there any way to measure if my disc mount on my forks is already +mm? Can anyone advise me on what rotor to get also? Cheers. Had in mind either the Hope Saw, the Gusset R-Series or the Hope Mono Edited December 20, 2010 by Jon Alty Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 20, 2010 Report Share Posted December 20, 2010 I'd say the only disadvantage is the fact it's easier to catch it on stuff when your riding but I wouldn't worry too much about it! The best way to check the size of your mount is to fix your caliper to your forks and measure from the axle to roughly where the disc sits on your caliper and times that by 2, not highly scientific but should do the trick. As for the disc I'd go for a standard mono trial disc personally. Quote Link to comment Share on other sites More sharing options...
