Pepo09 Posted December 19, 2010 Report Share Posted December 19, 2010 Frame and Forks Frame: Zoo Piranha 09 Forks: Echo Urban 09 v-brake/disc Wheels - Front hub: shimano - Rear hub: echo TR 09 - Chain tensioner: home made - Front rim: alex - Rear rim: Echo Sl - Rim tape: home made - Inner tube (front): cst - Inner tube (rear):cst - Front tyre: tioca - Rear tyre: Bontrager Big Earl Brakes Front Brake: shimano v-brakes , shimano cabel avid lever Rear Brake : shimano v-brakes, shimano cabel shimano lever Drivetrain - Cranks:Echo TR 09 FW: Echo TR 09 - Chain: KMC - Rear Sprocket: Echo TR - Pedals: wellgo - Bottom bracket: VP 127.5 - Bashring: Bionic Steering - Headset: Neco - Stem: ?¿ I am getting an Echo Sl 130/18° silver - Grips: Echo rubber - Handlebars: GT I am getting Try-all rage 09 Geometry Wheelbase: 1090mm Chainstay Length: 383mm BB Rise: 35mm Head Angle: 72 degrees Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted December 19, 2010 Report Share Posted December 19, 2010 Deffo change stem and bars, but get Trialtech sport riser bars and Trialtech sport high riser stem. If you still wanna get the Echo SL then get the 138mm/25 rise and not the 130mm/18 rise. Quote Link to comment Share on other sites More sharing options...
Pepo09 Posted December 19, 2010 Author Report Share Posted December 19, 2010 Deffo change stem and bars, but get Trialtech sport riser bars and Trialtech sport high riser stem. If you still wanna get the Echo SL then get the 138mm/25 rise and not the 130mm/18 rise. why?? I prefer a lower profile Quote Link to comment Share on other sites More sharing options...
