trials4life1 Posted December 19, 2010 Report Share Posted December 19, 2010 so my lever comes in as normal and releases normal but as i pull it back in for the second time it seems as the pistons are not coming back out, they are really slow. ive bleed it a few times now, it hasn't done much at all. any help or advise would be helpful also which refills either TNN LGMs, or Belaey ones. Cheers James Quote Link to comment Share on other sites More sharing options...
SamKidney Posted December 19, 2010 Report Share Posted December 19, 2010 What are your brakes bled with? Mine used to do this but was due to me not rebleeding my Anti-Freeze/ water bleed after 3 months. If it is water bled, drain the water, take apart the full brake and give everything a bit of a lube. Drop something like 3 in 1 oil into the slaves and leave for a while, using some mole grips to pull the cylinder in and out. Same with the piston in the lever. Give it all a clean and rebleed. Should be fine after that. Im due to do mine soon but will be rebleeding with PhatPhluid Should put an end to my water related issues Quote Link to comment Share on other sites More sharing options...
