Up To Rear Wheel Technique
SamKidney
As the title says, I'm asking for any advice on techniques to get my taps up to rear wheel any higher.
Highest I can get is about 3 ft atm and the same from static.
Ive been at this level for quite a while now and would like to progress :)
Any advice welcome
Thanks
edited haha
Edited by Echo Lite 09
heh no worries dude...
Watch some slowmo stuff of benito backwheeling stuff, the way he lunges into the bars the wrenches his weight backwards to lift the bike up. Also, try and make you and your bike follow the wall as you go up, instead of flying at an angle into it. This means you effectively have to travel a smaller distance.
Wouldn't reccomend copying his pedal stroke though :lol: App' he runs an 18:14 ratio.
Lift wheel on bad foot.
Well said. This is the best way IMO, lots of people wait until the strong foot comes round to lift the front wheel and it looks rushed and uncontrolled.
It's all about timing of the body movement and rotations. After a few thousand goes it should click pretty good.
Yeah I already use my bad foot to raise the front wheel, but was lacking in my technique.
Been out today on some pallets and the highest I could get was around 5. By leaning back, being more powerfull in my pedal stroke and speed and lunging the bike straight up I managed 7!
My sidehops have also improved, by learning to preload quicker as I did with the up to backs.
I found the best way to improve my taps, is to practice pedalling up to back wheel without a tap...
It helps you to concentrate purely on the physical jump and leg power required to get up high walls. I've found when all I do is practice taps, I get a bit lazy with the jump and rely on the tap to get me up. That's fine up to about 4 ft but if you want to get higher you really have to have a strong jump. Also the full pedal technique helps as mentioned above, as does practicing with short run ups and watching videos of people who can tap really well.
My taps have been stuck at the same height for 6 years now :turned:
Bit of advice I got of a dude that tap like the best of them was as well as lifting from the bad foot, really have your weight back when you lift, as the good foot comes round for the power stroke you travel forwards so that you are really sending your weight into it at the point of front wheel impacts the wall.
