Could Anyone Give Me A Detailed On How To Paint A Frame Or Any Compone
Gaz96
I have an old frame I could practice on first aswell
You need to strip the frame (Nitromorse)
You need to spray it with primer
You need to spray it with colour
You need to spray it with lacquer
You might want to try searching - it's a proper long process to type out in detail and it's been done many times as I'm sure you can imagine.
I did a rush job.
  • Sanded it down.
  • Primer
  • primer
  • Paint
  • Paint
  • Lacquer
  • Lacquer
Let it dry in between layers, and use VERY fine sandpaper and rub it down in between layers.
When I say I rushed mine, I didn't follow the advice I just gave and it turned out okay, but could have been MUCH better.
All supplies can be picked up from halfords, and they usually have some offers on.
Edited by xDUNSTANx
