matt.price Posted December 16, 2010 Report Share Posted December 16, 2010 Hi guys, indeed of some help.. I have reccently had my bike back from local bike store after they repaired one of my threads on my 4 bolt mounts. But now i have built my bike up.... on the right side of my mounts ( not the re-paired thread ) my bolts don't seem to go in properly !! the bolts wind into the threads fine till they go really tight .. but the bolts arn't down enough so they don't clamp the mounts ! It is the exactly the same setup as before i had it repaired ! Help !! any help would be great... thanks loads matt Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted December 16, 2010 Report Share Posted December 16, 2010 Did they helicoil the mount? if they have, they might have left the little tab in the bottom of the helicoil, and your bolt might be butting up against it. Either that, or the threads on your bolt are worn or dirty, have a good look at the threads and look for knackered bits Quote Link to comment Share on other sites More sharing options...
matt.price Posted December 16, 2010 Author Report Share Posted December 16, 2010 Did they helicoil the mount? if they have, they might have left the little tab in the bottom of the helicoil, and your bolt might be butting up against it. Either that, or the threads on your bolt are worn or dirty, have a good look at the threads and look for knackered bits this is on the other side were there repaired bolt isn't . do i just load the thread with grease or how to i clean it? cheers for the quick reply Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 16, 2010 Report Share Posted December 16, 2010 Have you tried dropping an allen key or something into the hole to see how deep it goes in case something is stuck in the bottom? Quote Link to comment Share on other sites More sharing options...
matt.price Posted December 16, 2010 Author Report Share Posted December 16, 2010 i've just messured the thread which is fine and the threads that are being an ass ! they're both the same length what could of happened? i've tried the threads with two different types of clamps so i don't get whats wrong !! cheers for help so far. Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 16, 2010 Report Share Posted December 16, 2010 Can only assume it's been cross threaded then, take it back to the bike shop and see if they know owt about it. Quote Link to comment Share on other sites More sharing options...
matt.price Posted December 16, 2010 Author Report Share Posted December 16, 2010 Can only assume it's been cross threaded then, take it back to the bike shop and see if they know owt about it. surely if it was cross-threaded it would be just really stiff from the start? will ring lbs in morning to see if i can bring it in but if snow comes.... Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted December 16, 2010 Report Share Posted December 16, 2010 surely if it was cross-threaded it would be just really stiff from the start? will ring lbs in morning to see if i can bring it in but if snow comes.... depends where the crossed thread is Tried a different bolt in the hole? If you've got a brand new one lying around, try that too Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted December 16, 2010 Report Share Posted December 16, 2010 Sounds like your bolts are bottoming out., get a link of chain, take out the little roller and use that as a spacer washer on the bolt. Sorted Quote Link to comment Share on other sites More sharing options...
matt.price Posted December 16, 2010 Author Report Share Posted December 16, 2010 Sounds like your bolts are bottoming out., get a link of chain, take out the little roller and use that as a spacer washer on the bolt. Sorted sorry but what does bottoming out mean? cheers for all the help Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted December 16, 2010 Report Share Posted December 16, 2010 Hitting the bottom. Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 16, 2010 Report Share Posted December 16, 2010 sorry but what does bottoming out mean? cheers for all the help He means they're screwing in as far as they can go, but that would be odd as I assume the bolts went in fine before. If it's been cross threaded your bolt could be screwing in the dodgy thread thats been cut in and when it gets to the end of that and meets the normal thread it won't go any further, thats what I meant! Quote Link to comment Share on other sites More sharing options...
matt.price Posted December 16, 2010 Author Report Share Posted December 16, 2010 Hitting the bottom. oh... but what i don't get is why it bottoming out now , because they fine before? must be a cross thread. but will but a spacer or two on it for now.. cheers again for everyones help. (Y) Quote Link to comment Share on other sites More sharing options...
matt.price Posted December 16, 2010 Author Report Share Posted December 16, 2010 just sorted it guys put some of those little rings off a chain ( like alex said ) thanks for the 10th time matt Quote Link to comment Share on other sites More sharing options...
