PeanuckleJive Posted December 18, 2010 Report Share Posted December 18, 2010 I'm not doubting you, but I don't get how the metal washer would be better? Can you explain Oops, forgot to answer this. It's just miles better than using the standard plastic clip around the cylinders, the plastic clips bind on the cylinders and the clamps really easily and it can make it a pain to set up good every time, the metal half washers on the SL clamps just allow you so much more room to move, and stay put when you want them to. I can set my brake perfect every time so quickly now, used to take me aaaaaages with my old clamps Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted December 18, 2010 Report Share Posted December 18, 2010 Oops, forgot to answer this. It's just miles better than using the standard plastic clip around the cylinders, the plastic clips bind on the cylinders and the clamps really easily and it can make it a pain to set up good every time, the metal half washers on the SL clamps just allow you so much more room to move, and stay put when you want them to. I can set my brake perfect every time so quickly now, used to take me aaaaaages with my old clamps It's much easier with Echo TR clamps, you don't have to use a washer at all Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted December 18, 2010 Report Share Posted December 18, 2010 It's much easier with Echo TR clamps, you don't have to use a washer at all Try reading my original post again. TR clamps are fine and dandy will obviously work fine, IF your mounts are square and straight. Nowadays you can be pretty sure your mounts are on the frame properly, but for all the other cases, there's SL clamps... Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted December 18, 2010 Report Share Posted December 18, 2010 Try reading my original post again. TR clamps are fine and dandy will obviously work fine, IF your mounts are square and straight. Nowadays you can be pretty sure your mounts are on the frame properly, but for all the other cases, there's SL clamps... Suppose, I only really think its easier because I can't use the normal clamps and washers, too hard to set up and take too much time haha. Yeah, the mounts being square is annoying, because i always think mine arent when they are Quote Link to comment Share on other sites More sharing options...
alex-trials-boy Posted December 18, 2010 Report Share Posted December 18, 2010 My Try-All clamps are mint no washer needed fantastic to set-up. Quote Link to comment Share on other sites More sharing options...
